Old 02-15-2004, 06:32 PM   #1
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Default TC3 One-way?
Hey what are the advantages/ disadvantages of this. Who makes a good one and about what price?
tc3stocker is offline   Reply With Quote
Old 02-15-2004, 07:25 PM   #2
DT-Skyline's Avatar
Send a message via AIM to DT-Skyline Send a message via Yahoo to DT-Skyline Send a message via Skype™ to DT-Skyline
The advantage of a way one is it has more power during turns and is fully all wheel drive all the time. Much faster in the starights . The disadvantage. IDK
DT-Skyline is offline   Reply With Quote
Old 02-15-2004, 07:36 PM   #3
Me+RC=$$$'s Avatar
Send a message via AIM to Me+RC=$$$ Send a message via Yahoo to Me+RC=$$$
the disadvantage of a one way is when u tag a board, ur very prone to bending or breaking a CVD bone.
Me+RC=$$$ is offline   Reply With Quote
Old 02-16-2004, 12:02 AM   #4
fatdoggy's Avatar
R/C Tech Charter Subscriber
Provided your track has half decient traction, you'd probably be faster with a oneway. You'll have more pull out of corners and a crap load more steering. You'll have to change your chassis setup for the oneway though. Dual rates will also have to be turned way down in most cases from 100% to say 50-75% depending on your track. It's all personal preference, some people hate oneways becuase they use alot of braking due to their driving style. I don't brake much so a oneway works well with my driving style and helps me keep tighter lines.
fatdoggy is offline   Reply With Quote
Old 02-16-2004, 01:24 AM   #5
Cole Trickle's Avatar
Good grip, you can give it a try. Medium to low grip, I wouldnt do it.
Here you can read more: http://www.rccaraction.com/articles/oneways.asp
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-16-2004, 01:50 AM   #6
gee-dub's Avatar
advantages - more (especially off-power) steering, no diff to unload during hard cornering, front end pulls adding steering out of the corner
disadvantages - more (especially off-power) steering, more mass/weight, makes using brakes very difficult (car wants to trade ends in lower traction conditions), easier to bend/break axles as there is no diff in the drivetrain to transfer force to
in a nutshell, a one way adds steering. you'll notice the effects of a one-way the most when entering a corner. under hard cornering, a diff can actually unload the inside tire resulting in 'push'. with a one way, the car tends to turn in much more aggressively. like anything else, it's a tuning option. unless you're racing at just one place, and the one-way is not the hot setup, you should have one in your pit box.
as for who makes a good one, the version 2 tc3 one ways from associated are very reliable. they are manufactured by yokomo, and were originally used in the ntc3, then marketed as a 'heavy duty' option for the tc3 (uses different outdrive cups than ntc3). i believe currently they're just labelled as a plain old 'one way' (no more 'heavy duty').
price, between 52-60 depending on the shop.
if any of this is incorrect on the making/manufacturing portion, please correct me, it is all second hand info.
gee-dub is offline   Reply With Quote
SEO by vBSEO 3.5.0
