Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-14-2009, 11:19 PM   #1
Tjay's Avatar
Exclamation TC4 Gear Ratio... help!
Hi,
I bought a used TC4 Team Kit. It comes with 104t-64pitch spur. The differential gear and shaft gear are all stock. The question is, how do I calculate the gear ratio?
Just so you guys know, the car is going to be set-up with 17.5 duo brushless motor with SPX speed control.
Thank you!
________________________
TJ Macabuhay
www.fastpaceracing.com
Tjay is offline   Reply With Quote
Old 10-15-2009, 03:53 AM   #2
heretic's Avatar
the internal ratio is 2.5; that is: (diff gear) divided by (small bevel gear)=2.5
your spur /pinion ratio is : (Spur-104 teeth) divided by (pinion, say 36 teeth)=2.88
then: 2.5X2.88= 7.22 ET VOILĄ !
for a 17.5 I would start with a FDR of 5.2ish for a medium sized track... so :
5.2 divided by 2.5= 2.08
104 divided by 2.08= 50, so you are looking for a pinion of 50 teeth... probably a bit more or less, of course, it depens on a lot of things.
Remember that a SPX requires a higher FDR ( smaller pinion) than regular escs when it is used in program "turbo" 7 or 8.
Ask at your track, and don't let anything become too hot.
have fun, the tc4 is a really good car.
heretic is offline   Reply With Quote
Old 10-15-2009, 03:18 PM   #3
Tjay's Avatar
I saved this info on my cell phone. Thank you very much! This helps out a lot!
TJ Macabuhay
Old 10-15-2009, 07:43 PM   #4
redmike76's Avatar
Trader Rating: 15 (100%+)
gearchart.com
Originally Posted by Tjay View Post
Hi,
Thank you!
redmike76 is offline   Reply With Quote
Forum Jump
Team Associated TC4 Kenshin Electric On-Road 9602 10-29-2009 07:37 AM
IPHONE GEAR CHART APP - HELP NEEDED ab1105 Electric Off-Road 9 05-03-2009 03:49 AM
IPHONE GEAR CHART APP - HELP NEEDED ab1105 Electric On-Road 17 02-20-2009 01:30 PM
Question About 64 pitch Gearing on My TC4????? SohcFTTC4 Electric On-Road 12 08-06-2006 12:57 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
