Old 10-13-2009, 10:51 AM   #1
drive2survive's Avatar
Trader Rating: 23 (100%+)
when you change out the lower suspension holders do all 8 have to be changed? and do those parts adjust the ride hieght?: can I also assume I need .5 MM at all corners ?, heres another one>>>>>>>the car came with a multi diff in front, should that be changed to a reg. diff? Ill be running on asphalt
drive2survive is offline   Reply With Quote
Old 10-13-2009, 11:00 AM   #2
rcterp's Avatar
Trader Rating: 35 (100%+)
I assume you talking about the blocks that hold the arms on; if so, they do not affect ride height, they affect roll center, anti-dive, kick-up, anti-squat, etc.
On asphalt most people run either a spool or a one-way (depends on driving style and track) so keep the mulit-diff in it.
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 10-13-2009, 11:03 AM   #3
lochness42's Avatar
Lower suspension holder are for altering roll center not ride height. You should have at front same 4 holders and same at rear. Front and rear don't have to be the same. You also can do some experiments with pro/anti squat.
For front axle - most used atm is spool - composite is better than multidiff locked. If you're racing foams front diff is way to go. On some occasions one way can be used as well.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
SEO by vBSEO 3.5.0
