Old 12-10-2013, 05:18 AM   #31
there is no single best additive for every track you need to find out what the majority use as use that, reason being other additives may react with it and give strange grip characteristics
this is evident at my local carpet track where it has a lot of LRP and nosram water based additive used, spider grip ended up giving weird traction
PurcyP is offline   Reply With Quote
Old 08-31-2014, 09:03 AM   #32
stro3579's Avatar
Trader Rating: 20 (100%+)
Default Gription
Gotta try this stuff. Works great on low and high traction tracks.
stro3579 is offline   Reply With Quote
Old 08-31-2014, 10:53 AM   #33
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Originally Posted by oeoeo327 View Post
I wish it were truly that easy... Finding good grip on a variety of surfaces usually requires several different traction recipes. However, if I'm struggling for grip and running outdoors, I'll clean my tires with lighter fluid, and use a combination of Buggy Grip (apply and let dry) and Tire Tweak.
That's the most consistent combo I have found outdoors, running VTA. Usually works every time.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Rubber tires for dummies rayhuang Electric On-Road 391 06-02-2012 07:37 AM
Tire prep for rubber tires on carpet gotyournumber Electric On-Road 19 02-07-2012 04:07 AM
Traction Compound Alternatives Rockin Johny Electric On-Road 23 07-22-2008 01:50 AM
tire traction compound...how long to soak? lateapex Electric On-Road 19 02-22-2005 12:18 AM
Rubber tires on carpet? Speedie Electric On-Road 20 11-05-2003 03:52 PM
SEO by vBSEO 3.5.0
