Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-10-2009, 12:05 PM   #1
Default TC5R torque steer?
So I got a TC5R rubber tire edition, and im setting it up for top speed. I have a MM 7700 motor in it. But Im having trouble with it veering way far right when i give it just slight throttle, but then i get off the throttle it goes straight. I have adjusted my camber and toe to correct for this, its a little better but it still drifts right. I dont know what else it could be. Any one have any tips on what might be causing this? Also when i slam the breaks on, right before it stops it does a 180 left. Somethings not right. I got my diff in the back loose and I have a spool in the front. Any Ideas?
grvn is offline   Reply With Quote
Old 10-10-2009, 12:38 PM   #2
ZEe_NYC's Avatar
there's definitely some kind of binding somehwhere.
check all the screws to make sure everything isn't TOO tight. Also check the bearings on all 4 corners. Check that the drive shafts aren't binding up anywhere. are they well lubed?
it might not be something in the front... it could be one of the rear wheels is dragging and causing it to veer to one side.
ZEe_NYC is offline   Reply With Quote
Old 10-10-2009, 01:19 PM   #3
Check your droop and your hinge pins.
bukil is offline   Reply With Quote
Old 10-10-2009, 01:33 PM   #4
I vote for droop. As you accelerate the front is being lifted off the ground just a little bit leaving the back to do most of the work.
MonkeyFist is online now   Reply With Quote
Old 10-10-2009, 01:46 PM   #5
Dave Bowser's Avatar
Trader Rating: 30 (100%+)
if your car has a slipper spool its probably loose you just need to tighten it up and the car will go straight
RCAmerica, X-Ray, Hudy, Fantom, Novak, Ko Propo, Protoform, PRS, Jaco, SMC, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, Team Power Stroke, NEXT
Dave Bowser is offline   Reply With Quote
Old 10-10-2009, 01:54 PM   #6
revo61's Avatar
Trader Rating: 8 (90%+)
The TC5R does not have Torque steer. Make sure it balanced, weight the same on both sides. That Mamba system is on the heavy side, if you run lipo. Add weight to lipo side.
Hot Bodies D8 .21 Vspec
Team Associated TC5 Team Orion 10.5/LRP TC
DX3R/Hitec servos
Odonnell Fuel
www.tallahasseerc.com
revo61 is offline   Reply With Quote
Old 10-10-2009, 02:33 PM   #7
Front spool is good. Not a slipper, its tight, droop is good. nothing is binding. I just trimmed a little left when giving it throttle, and it takes off straight now. and it has a slight left drift when slowing down, i might adjust the toe out position a bit, there is some slop in the front steering linkage so ill play around there some more. I did move my shock mounts on the arms from farthest out to next one in on the front and back and did the same on the back. I tightened up the back a bit too. Charging my batteries now. I hit 60, Only 40 more mph to go! Im sure a 4S pack should do the trick!
Old 10-10-2009, 03:56 PM   #8
Ok so i tightened up the steering post, not the post but the nut that is on the bottom of it. That helped some too. It just seems that there is a lot of slop in the steering. If I set my trim just right, on one run it will veer slightly left, and on another if will turn slightly right. Is there any tricks out there to tighten up the steering? Like over sized balls or undersized cups?
Old 10-10-2009, 04:13 PM   #9
My TC4 was famous for this. The answer was to replace all the steering ball cups and camber link ball cups with RPM short ball cups.
Eddie_E is offline   Reply With Quote
Old 10-10-2009, 05:23 PM   #10
Trader Rating: 15 (100%+)
That's because the TC4 is a shaft driven car, all shaft driven cars had torque steer issues with which is why most touring cars are now belt driven..
trerc is offline   Reply With Quote
Old 10-11-2009, 12:15 PM   #11
Alright, I hit 55.1 mph via GPS. That was with out the body on it. Full throttle. Then I put the body on it, the body doesnt have a rear spoiler due to a wreck. And I couldnt get past 30 with out spinning out. Can any one recomend a good body with some decient downforce? Im going to need something once i start getting closer to 100.
Old 10-11-2009, 02:38 PM   #12
joe of loath's Avatar
Well, I use a dodge stratus for high rear downforce (its on my custom built RWD car), but most people doing speed runs go for an HPI body I can't recall right now, with only the front wheel arches cut out.
HPI E-Firestorm - Traxxas Revo - Tamiya TA05 - Custom built TC
Pastafarian and proud.
a_main_attendee: don't be dissing ma spinnin doritos dawg!
joe of loath is offline   Reply With Quote
Old 10-11-2009, 03:05 PM   #13
Foxxrocket's Avatar
+1
weight makes all the difference. If the right side of the car is heaver than the left, then the car will tend to lean to the right. Having equal weight on all four tires will straighten the car out.
Associated TC4
Associated TC3
Associated 10R5O
Kyosho Inferno GT2
Traxxas Slash
Foxxrocket is offline   Reply With Quote
Old 10-11-2009, 03:11 PM   #14
Hide's Avatar
Take out motor and check for binding. Although it is probably lipo balance issues, weight etc.
This body is good for +140mph. https://www.ssl-stormerhobbies.com/c...c=ns&pn=MCA197
From Shawn Palmer:
Level 1 - basically no real experience with RC cars capable of 60mph:
I'd definitely start with diff/diff. Check out www.gearchart.com and gear your car for about 60mph and start making passes. When that's boring, kick it up to 70mph and repeat. When that's boring, kick it up again. Most of us come to a wall the first time we start approaching 80mph. Be it aero, motor power, gearing limitations, range - it's always something. Work through that (and we're all here to help you) and you're at level 2.
Level 2 - knocking on the door of 100mph. You're familiar with the car, aero stuff and how to drive a car with a ton of power. This is where I'd swap the diff in the rear for the one way. BUT - back off the gearing/speed when you run it the first time to get a feel for how it's going to act. Work up to faster speeds slowly like the above. Here you'll need to systematically fine tune the aero, power, range and etc to get faster. And again, we're here to help!
Level 3 - Totally comfortable at 120 and searching for more speed. At this point, you have realized power in no longer an issue, but everything is centering around aero, range, your own limits of vision, and how much traction you can get. At this point (for me anyway) the spool front/one way rear becomes a near necessity in a 4wd TC. This kind of power shreds diffs in no-time, and in my personal experience they make the car a little directionally unstable as well (most likely because they are in a state of coming apart LOL).
What tyres are you running?
Email BSR: teambsr@att.net. They'll set you up with the best wheels/tyres for speed runs.
Lastly, join www.rc-isc.com.
TC5 FT Speed car, LRP Shark, eJato, Xray M18T custom extended, Traxxas VXL Revo, E-Maxx
Hide is offline   Reply With Quote
Old 10-11-2009, 05:15 PM   #15
Thanks Hide! Yea im pretty sure its not a weight thing. It does it with a light 2100mah battery and with a 5400mah battery. Steering is just sloppy i think. I put on a 40 tooth pinion today with a 3S lipo. I hit 76.7mph with no body, it was flying. but sadly i lost a screw that holds on a wheel arm. so im gana have to go get some more and some lock tight tomorrow. I have my 4S all charged up, hope fully i can get up past 80. from 2S to 3S i gained 10 mph. And I know im losing some mph due to aerodynamics. Ill order that body and maybe a 6S
Forum Jump
Team Associated TC5 RCknight Electric On-Road 11416 Today 01:12 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
