XRAY T3
#241
have you ever found that you'd like to have more motor adjustment when chasing a certain FDR?
I am asking because I tried running a 21.5 motor and found that I had to have huge pinions. The range of spurs available from Xray didn't help either (and I didn't really want to buy any more spurs/pinions as I already have an impressive collection).
#242
The car looks nice. 4mm wider battery slots, ummm... I'm guessing there are battery locators on the inside as well so the battery can't slide into the belt if it cops a bump?
#243
#244
And the Schumacher Mi4.
#245
if you hang lipo out from chassis you can even do it on 008 LOL
#246
Plastic vs aluminum shock bodies
I see a few people don't like the plastic shock bodies. Plastic shock bodies have been used by XRAY for a while and I believe they are better than aluminum bodies for one major reason. Plastic does not absorb heat. Aluminum does and does it very well. It then transfers that heat to it's surroundings. Outside the shock body is fine, but inside is very bad. The shock oil will heat up further and breakdown quicker. Not good. It seems a little cheesy, but it is really effective and shows foresight. But if you race indoors, you probably won't notice a difference.
#247
#248
+1
99% of UK team uses alloy shocks
#249
Suspended
the paying public wants aluminum shocks bodies and for the price tag that going to be attcach to this car they should be included I see that your sponsored or drive for MUGEN SEIKI USA do they they have plactic bodies or any bodyelse for that matter HEAT HAS NOTHING TO DO WITH IT. TRF has the best shocks in the business and guess what their made out of aluminum
#251
...but I put TRF shocks on my MTX4R because I too believe they are the best electric shocks out and guess what? They exploded under the heat and forces associated with nitro racing. And the heat changed the color of the blue anodizing in a five minute run. You can't compare electric and nitro. The heat produced from a nitro car would compromise plastic shock bodies during long runs (though the NT1 uses them too and they have the US Championship... Go figure.) You need to change shock oil every several runs to get a consistent nitro damper...just like most other aluminum "electric" shocks I've used.
#252
Every R/C car I've owned in the last 10 years or so has had Lundsford turnbuckles and Tamiya TRF shocks put on the car as soon as its built.
I didnt do that with the Xray. I put the Xray aluminum shocks on the car and I can tell you they are just as good as the TRF and Schumacher shocks. They are extremely consistent, smooth, and easy to bleed. Setting rebound is also easy.
#253
ECS driveshafts are an option, and not all the team driver choose to use them. They therefor aren't essential (as well as being more expensive to fix if something breaks!).
I must confess I couldn't care less about the main shock body material. Before I was running Xray I used to wonder why they still ran plstic shock bodies. Because they are fine!
I would rather Xray supplied better pistons like Xray/Tamiya etc.
They use machined nylon which are are far smoother, with Xray's we have to cut them off the sprue which makes it far harder to ensure that the piston has the same profile all the way around.
Skiddins
Skiddins
#254
The Evicerator
Steve,
I think that unless you're WAY off on your gearing there's generally enough room.
I like to stick with the biggest spur gear I can and gear accordingly.
#255
