XRAY T3
#2461
You should be able to make it a perfect 100% L/R balance by adjusting the servo link.
Pretty much, the only thing I adjust from my radio is steering travel/dual rate. Keeping it simple.
Bill
#2462
now back onto the weight issue.....my car sits flat on the points as is but like i said have to add 80 grams yet.....what does everyone use...just the standard stick on tire weights...or does someone have a better idea??
thanks
p.s anyone use these????
http://rcmarket.com.hk/product_info....oducts_id=7844
thanks
#2463
thanks
thanks
#2467
Have u run the T3 chassis yet? i tink it will work juZ fine. Otherwise u cld wait for aft the worlds before deciding to get the exotek.
#2470
#2473
Is there a shim kit for getting different inboard toe settings?
#2475
R/C Tech Elite Member
i've been running 10 grams at the Front Left and Front Right of my cars -- using either tire weights or XRay 309840. Behind the battery on the Rear Right I run 15 grams again with either tire weights or XRay 309840. On the Rear Left behind the motor I run a fan (about 5 grams). The remainder of the weight I put in the center line of the chassis using tire weights. Just make sure to offset the weight slightly to the left in order to keep their weights from rubbing against your belts.
