Old 10-07-2009, 03:53 PM   #1
Default brushed motor
what is the difference between 6s motor and 4s motor?
nitro expert is offline   Reply With Quote
Old 10-07-2009, 08:24 PM   #2
Big Midget's Avatar
Trader Rating: 98 (100%+)
I've never heard of a 4s or a 6s motor, I could be wrong. There are 4s/6s lipo packs.
brushed and brushless motor are rated by turns 10t 13.5t 3.5t or for some brushed 13x2 would be a 13 double.
Hope this helps
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 10-08-2009, 03:38 PM   #3
What he said above.
Also in electric aviation and high velocity cars you'll see motors driven by 4s or 6s LiPO packs, which have very high voltage.
Generally a high voltage motor has more turns of thinner wire than a motor designed to make roughly the same power from a lower voltage, say the standard 2s LiPO in RC cars. Otherwise the high voltage motors would fry from over-current in the windings. A high voltage motor is more efficient at converting energy to work (wastes less energy as heat) and therefore is preferred for systems where the voltage source is not a design constraint.
SystemTheory is offline   Reply With Quote
Brushed motor vs regular larso10 Electric Off-Road 6 10-05-2009 06:31 PM
Better Brushed Motor??? RCRat Electric Off-Road 29 08-28-2008 07:02 AM
4wd Buggy Brushed Motor Selection Help TexasPete Electric Off-Road 57 08-04-2008 11:00 AM
Best brushed motor and ESC knucklebusta Electric Off-Road 6 01-06-2006 11:40 AM
SEO by vBSEO 3.5.0
