World gt weight
Old 10-02-2009, 08:09 AM
Default World gt weight
I am wondering how I am giong to get my car ready to run 930g any suggestions?
Tulsa TC3 is offline
Old 10-02-2009, 08:16 AM
escpecially when the car already weighs 1.98lbs. or 898.11 g and the SMC weighs around 100g's itself???? IM stumped
Old 10-02-2009, 08:20 AM
PitNamedGordie's Avatar
Actually at the IIC my car was underweight at 924 grams.
I was using SMC pack and was running my tires small...52mm rear and 51mm fronts. It also depends on the car you are running...there were other things I did. But with that said I had a lot of trouble with my car at the IIC. So my being light made no difference.
PitNamedGordie is offline
Old 10-02-2009, 08:30 AM
I am running 10r5 with a supra body, smc 4000, gtb 4cell, jr 3650 300mah servo pack with light light weight voltage regulator. My main issue is balance. I want to get close to weight as possible but I think balance is the most important aspect of these cars. I made a balancer out of a heli blad balance point and mounted it to some jaco greens(looks kinda cool) I have thought about putting my ESC in front of the shock in the center of the car, good or bad idea all I think is push push push when I think of that as an option.
Chris Totcky
Old 10-02-2009, 08:53 AM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
you're running a 4 cell battery?
Cpt.America is offline
Old 10-02-2009, 08:55 AM
no sir the 4cell GTB with a smc 4000 single cell......
Old 10-02-2009, 09:06 AM
and if someone could explain what the different profiles on the 4 cell gtb do that would help alot . I have never ever messed with any of my settings
Old 10-02-2009, 04:15 PM
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I also had to add lead to my 10r5 in vegas to make 930. No optional parts or al/ti screws. All steel. Sophia body, rs esc, 9650 servo, Spektrum micro, speedpassion 13.5, mrt PT. It only took about 14-21 grams to make balance, and another 14 grams to make weight. SMC 4900 with bullet connectors and 16g wire all around.
andrewdoherty is offline
Old 10-02-2009, 06:11 PM
tallyrc's Avatar
balance and setup is far more important than shaving the extra couple ounces, though it would be nice..
tallyrc is offline
Old 10-02-2009, 06:56 PM
Trader Rating: 16 (94%+)
All the profiles do on the GTB is to control Punch by limiting how quickly it ramps up to 100% throttle. The GTB does not adjust the timing like other speedo's, so adjusting the GTB Profiles will not have much impact on the car.
kn7671 is offline
Old 10-02-2009, 10:07 PM
mikel33's Avatar
Trader Rating: 2 (75%+)
How much paint is on the body? Also, how much wire for the speedo/motor and what gauge? The tires make a difference as well. I think you are running a GTB? The GTB is a fairly heavy speedo and it has that huge cap. I dropped quite a bit of weight when I went to lighter electronics. Having said that, with a 1 cell set-up you might be able to lose the fan and heat sink off the GTB.
as far as balance: I am far, far from one of the experts, but if you are going to be fast you have to be balanced and at the minimum weight.
mikel33 is offline
Old 10-03-2009, 10:56 AM
it also wouldnt hurt to ditch the receiver pack AND voltage regulator, and go with a voltage booster instead. They are tiny and weight almost nothing.
Old 10-03-2009, 12:28 PM
Default Body advice
Could someone advise me the best Gt body, i am running on an outdoor asphalt track...
Mulsane, Sophia, maybe an other??
Yann
Yannb is offline
