World gt weight
World gt weight
I am wondering how I am giong to get my car ready to run 930g any suggestions?
escpecially when the car already weighs 1.98lbs. or 898.11 g and the SMC weighs around 100g's itself???? IM stumped
I was using SMC pack and was running my tires small...52mm rear and 51mm fronts. It also depends on the car you are running...there were other things I did. But with that said I had a lot of trouble with my car at the IIC. So my being light made no difference.
I am running 10r5 with a supra body, smc 4000, gtb 4cell, jr 3650 300mah servo pack with light light weight voltage regulator. My main issue is balance. I want to get close to weight as possible but I think balance is the most important aspect of these cars. I made a balancer out of a heli blad balance point and mounted it to some jaco greens(looks kinda cool) I have thought about putting my ESC in front of the shock in the center of the car, good or bad idea all I think is push push push when I think of that as an option.
Chris Totcky
Chris Totcky
no sir the 4cell GTB with a smc 4000 single cell......
and if someone could explain what the different profiles on the 4 cell gtb do that would help alot . I have never ever messed with any of my settings
I also had to add lead to my 10r5 in vegas to make 930. No optional parts or al/ti screws. All steel. Sophia body, rs esc, 9650 servo, Spektrum micro, speedpassion 13.5, mrt PT. It only took about 14-21 grams to make balance, and another 14 grams to make weight. SMC 4900 with bullet connectors and 16g wire all around.
How much paint is on the body? Also, how much wire for the speedo/motor and what gauge? The tires make a difference as well. I think you are running a GTB? The GTB is a fairly heavy speedo and it has that huge cap. I dropped quite a bit of weight when I went to lighter electronics. Having said that, with a 1 cell set-up you might be able to lose the fan and heat sink off the GTB.
as far as balance: I am far, far from one of the experts, but if you are going to be fast you have to be balanced and at the minimum weight.
Body advice
Could someone advise me the best Gt body, i am running on an outdoor asphalt track...
Mulsane, Sophia, maybe an other??
Yann
Yann
