help with a new track
biggest track in Nederlands !!!! NEWS
i have just spoken to my boss about the 600 square meter werehouse we have above our showroom , my questions are this
A , can we race ok on concrete or does it have to be carpet
B, if it has too be carpet then which is best value for money ??
C, timing gear ?? AMB want €3200 for there decoder is there another brand that will work at the AMB PT's we all use ??
D, what is a good track layout ?? pictures are good too
If you're going to use AMB pt which most people use you will have to buy AMB's decoder. You may have luck finding an older AMB decoder unit that is for sale. Make sure it isn't the older AMB 20 decoder since it doesn't work with personals.
For the track surface concrete maybe alright but it depends on the surface smoothness, grip etc. You're probably better off using carpet (ozite?)that's made for racing rc cars on but I'm not the one to ask about.
For good track layouts I would look up big races such as Reedy Race of Champions, Snowbirds etc. for a good starting point.
hey phill
concrete works but you have to make it apsolute dust free.
and treat it with sucar water for best results
for carpet we use the lowest price carped.
for a layout use one off the nice ets layouts. its about the same size
so AMB have the monopoly and they can charge what they want for their stuff cos there is nothing else to use !!!!!!
ok so a Question for the european guys
who will sponser a new track ??
need carpet buying
need carpet buying
Sounds like you have a great possible venue for a track... 600m2 should give a good sized track and a nice amount of pitting too.
Carpet is the way to go. You can probably source it in the Netherlands, although it is called Ozite in the US (and we generally use stuff called PrimaFelt in the UK), it is basically a low-cost exhibition carpet.
You can get dust inhibitors for concrete. Companies like Sika or Fosroc make it. The advantage is that it won't wear out like carpet, and a mop can clean the crap off your track
THere is an alternative timing system out there, but I can't think of it off hand, do a google search. It's about 1/4 the price of AMB, but you can't use AMB PT's (small issue really).
Phil,
Just give me the length and width of how big you want to make the track itself. I will make some nice layouts for you...
Cheers mate...
Cheers mate...
KO propo makes a lap counting system... it is what we use at our small track... transponders are like $30usd no big deal
Alex
Alex
There are other systems out there but none are compatible with the AMB transponders. If you use one of them you will need all new transponders...the good news is they cost considerably less then AMB transponders.
Hi,
dont forget to make a few alternate courses, you will get tired of the same course over and over again, as for the flooring, i have no idea
We use rc lapcounter, ordered from USA.
Took 5 days to Norway, works great, cheap, small transponders. Overall a great system! For software we use LapsFree.
http://www.rclapcounter.com/
Email him and get a quote, he's very helpful! You can't go wrong with this setup!
ok i have emailed the people at the transponder company
does any one know how high the bridge sensors are ??
will 1/12th go over them without damage or causing the car to go airborne
thank you for all the advice whatch this space for info and track photos
