KO Esprit Vantage II - Help
Has anyone got a picture of the inside of a KO Esprit II vantage? I have a wire off and can't figure out where it's from??
A photo or circuit diagram would be great. It's a little red wire on the throttle stick.
Cheers
Cheers
ttt
Hi John,
Im from melbourne and am the only stick user at the Templestowe club. I use a JR X756 radio which im very happy with but you know, the Vantage is rather nice. Can you sugegst a place to get from the UK? It is hideously expensive to import whatever i think
Chris
The price has recently come down a bit, but still quite expensive.
If you import from the UK you get 17.5% discount as you won't have to pay VAT so you should get the tx only for about 150 pounds ($440) I would suggest :
www.clevelandmodels.co.uk
www.apexmodels.co.uk
www.modelsport.co.uk
Having just had the problem with the transmitter and taken the back off I can say that the quality on the inside isn't up to that on the outside.
Do you know anywhere in Aus I can get a 2 channel 40 mhz stick radio, everywhere I've rang only has wheels?
Cheers
John
BTW, from October you won't be the only stick user in Melbourne.
Cheers
John
