Old 09-11-2009, 06:10 AM   #16
mkdut's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Cpt.America View Post
I don't know about 12th scale, but at my large outdoor asphault track here, we run a WGT class and we run the following together:
13.5 1s lipo
13.5 4c subc
The nimh cars are signifigantly faster, even given the weight difference. I don't know exactly how much faster a 10.5 turn motor would be, but I imagine it would make the two chassis very close in speed... certainly closer than they are now... but alas, we only run 13.5 regardless of battery.
I would not call it significantly faster. In the infield there is almost no difference it is only when you get the long straights that the 4 cell will get up and go. The tighter the track the more the advantage shifts to the 1S. The real issue is when you are on a tight track the driving style between the two is different. You can really see the difference in weight come into play then.
mkdut is offline   Reply With Quote
SEO by vBSEO 3.5.0
