Like Tree15Likes
Old 05-05-2014, 05:11 AM   #1366
Originally Posted by 2wdrive View Post
Hi Hugo,
It is simplicity of the kingpin that makes most drivers go to the kingpin design. In theory front suspension with shock etc are better but when racing it really doesn't matter that much and the simplicity and ease of adjustments/maintenance etc of the kingpin makes it for many drivers an easy choice. Same for the back.
Experimenting is part of the hobby and it is fun to design something and show people your skills and idea's so please continue with the design and show the results .
Thanks for the reply. I'll stick with kingpin suspension for a start, keeping it indeed simple. I fear my rear suspension idea might die early, too, as I held some pro-10 cars in my hands yesterday and felt the torsional spring force and dampening, or rather the lack there-off. That also explanes how you can get away with simple kingpin suspension in the front, you hardly need anything there...
Another idea in the mind, please comment: I see many people concerned with ride height, and rightfully so, and all these cars use high downforce bodies and wings. So, ride height changes at speed. Ride height is high in the slow corners, where you want the CG to be low. Ride height is low on the fast straight because of the down force, but you don't need it there. Hmmm... Why not mount the body to the rear pod and the kingpins (some engineering required there...) so the downforce goes directly to the wheels, and the chassis can stay low to the ground all the time?
Just an idea. Please shoot! One thing that comes to mind is unsprung weight. Has anyone tried?
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 05-05-2014, 05:25 AM   #1367
howardcano's Avatar
Trader Rating: 35 (100%+)
Cheers,
Hugo
Yes, it works well. But you'll need to arrange some way to feed only the down force into the rear pod, and take out the lateral forces with a linkage or locating pin to the main chassis. Otherwise the handling will get weird.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 05-05-2014, 05:40 AM   #1368
2wdrive's Avatar
Yeah it is already being used. The pic is an example how it is done at the back.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-rc-devil-pc10h3x-01.jpg
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 05-05-2014, 05:50 AM   #1369
2wdrive's Avatar
Originally Posted by RoyU View Post
2wdrive, do you sell the upper pod plate?
organic is correct, i bought it from PRC but it is not availlable anymore.
www.rc-lemans.de
Old 05-05-2014, 06:15 AM   #1370
Originally Posted by Pro10noob View Post
Look closer at the car... It is a T-bar car and not a link like your showing
Yes, you're right.
but i see no screws on the sides of this Tbar, so the rear pod is totally free of rotation ?
Silverprout is offline   Reply With Quote
Old 05-05-2014, 09:44 AM   #1371
2wdrive's Avatar
the screws are in the front but aren't vissible in the picture. The two screwholes in the middle of the t-bar are not used. They were just for testing something wich didn't work out so I removed the screws. Depending on the grip or layout of the track I used T-bar screws or not.
www.rc-lemans.de
Old 05-05-2014, 11:12 AM   #1372
Do you change the T-bar sometimes ?
Do you have different tickness ?
Old 05-05-2014, 12:06 PM   #1373
Pro10noob's Avatar
Also running a T-bar car but with side dampers instead of damper tubes.
Not changing T-bars at all.
Just play with springs.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is online now   Reply With Quote
Old 05-05-2014, 01:26 PM   #1374
2wdrive's Avatar
I change t-bars when there is a stress mark in the t-bar. Or at the beginning of the year.
I played around with different thickness t-bars. With tweak screws you can really see and feel the difference. (like changing to a soft side spring). But to be honest I rarely use the thin t-bars, only when removing the tweek scews don't work.
www.rc-lemans.de
Old 05-06-2014, 09:20 AM   #1375
Why epoxy ?
Carbon is lighter and more nervous.
Old 05-07-2014, 02:06 AM   #1376
2wdrive's Avatar
Can you rephrase the question? I am not sure what you are trying to ask or tell.
www.rc-lemans.de
Old 05-07-2014, 03:03 PM   #1377
Abendor79's Avatar
I have always wanted to race a 235mm wide pan car. Are there any new 235mm wide kits available to buy?
Abendor79 is offline   Reply With Quote
Old 05-07-2014, 03:22 PM   #1378
spacendeman's Avatar
Send a message via MSN to spacendeman
There are several brands with a 235mm kit out of the box.
Corally 10sl , Hatzenbach and vip performance.
Also 200mm wgt cara can be made 235mm like the serpent and xray.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 05-08-2014, 01:22 AM   #1379
We could use carbon instead of epoxy to improve the T-BAR ?
Old 05-08-2014, 04:18 AM   #1380
howardcano's Avatar
The fiberglass/epoxy will flex much more than carbon before breaking. Since the T-bar is supposed to flex, fiberglass is the better material.
Spring steel is sometimes also used.
Howard Cano
Currently Active Users Viewing This Thread: 6 (4 members and 2 guests)
antlockyer, corn_bread, evochick, TOADYY
