Like Tree185Likes
Old 04-25-2014, 07:56 AM   #1336
OrganicMechanic's Avatar
Trader Rating: 33 (100%+)
This is my first post on this forum, but I have been lurking and reading trough threads for awhile now. Awhile back I picked up a Bolink Eliminator 10 roller for $25 and put it together with a 8.5T BL, BSR foams, PF P905B body and run it at my local IC track for fun during practice time. WOW is it fun and fast, so I decided to do some more research on pro10 to get a class put together with some friends and my brother. I've read all the threads I could find about pro10 235mm, over 200 pages worth of posts to give you an idea. I can honestly say this thread is the gold mine for pro10 info and ideas. You euro folks really get it! I read all 80+ pages of posts in this thread and found no arguments and no opinionated bs, just a relaxed atmosphere over flowing with great info that was a PLEASURE to read. Out of the 100+ pages of pro10 threads I read with mostly U.S. posters I found the complete opposite, everyone arguing over 200mm vs 235mm, battery size, pan vs TC, motor size, and other worthless squabbling. So I say THANK YOU! to all the euro folks in pro10 and I am using your relaxed and fun oriented format to get this class going with my group of rc enthusiasts.
OrganicMechanic is offline   Reply With Quote
Old 04-25-2014, 08:01 AM   #1337
Pro10noob's Avatar
Lol and your welcome.
In europe it is indeed fun all the way.
If you want to drive 200MM fine, if you want 235MM also fine.
If you want to run stock, great.
If you want to run insane fast, run the German rules.
Put in the car what you have and try to controle it
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-25-2014, 08:16 AM   #1338
TOADYY's Avatar
Send a message via AIM to TOADYY
OrganicMechanic welcome to RCTECH. Here is another thread dedicated to 1/10 Pan if you have not already found it.
1/10th pan car
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 04-25-2014, 10:12 AM   #1339
Thumbs up
@ Pro10noob
Exactly my sentiment. My brother wanted to set a spec motor size so I said to him whats the point? the track layout and traction available will determine that, lets just leave it all open and keep it fun and flexible.
@TOADYY
Thanks for the welcome, much appreciated. Thanks for the tip on the other thread also, that one may take a bit to read through lol.
Old 04-25-2014, 10:48 AM   #1340
Pro10noob's Avatar
Check the links
https://www.youtube.com/watch?v=hrxenwIkFXY
https://www.youtube.com/watch?v=pEYJdsGgCbA
Enjoy
Regards Roy
l===/o\===l
Old 04-26-2014, 06:35 AM   #1341
I wish we had an indoor track like that around here... Where is that track located? Is it the one I heard talked about in south Germany?
Old 04-26-2014, 07:57 AM   #1342
Pro10noob's Avatar
@Organic.....Yes it is in the south of Germany.
I believe in a town called Jestetten.
Was there when this clip was made
My team mate was running in that A finale.
Regards Roy
l===/o\===l
Old 04-26-2014, 08:33 AM   #1343
howardcano's Avatar
Trader Rating: 35 (100%+)
I'm not sure how far you are willing to drive, but I believe the Heart Of America series in Lincoln, NE, will be running 10.5T/2s pan cars this year.
Info here: http://www.rctech.net/forum/nebraska...ip-series.html
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 04-27-2014, 08:11 AM   #1344
Thanks for the tip on that race series! I've been to Nebraska before and a road trip is always an adventure, I just wish they had pro10 235mm class listed but all I see is WGT 200mm.
Old 04-27-2014, 10:19 AM   #1345
Which spurcount 48dp max for Serpent S100 in Pro10/235mm config
Furthermore:
are these
http://rcmarket.com.hk/index.php?man...&filter_id=112
the same as these
http://rcmarket.com.hk/index.php?man...sort=2a&page=4
Kensei is offline   Reply With Quote
Old 04-27-2014, 10:22 AM   #1346
Pro10noob's Avatar
Depends on track and motor which spur you need.
With 10.5, the most use 78 or 81.
With mod motors you need larger.
Regards Roy
Oops me bad
Thought you ment max teeth
Furthermore:
are these
the same as these
l===/o\===l
Old 04-27-2014, 10:45 AM   #1347
Julius's Avatar
Furthermore:
are these
the same as these
Yes they are similar, but not suitable for a pan car diff, as the balls are too close to the axle. Kimbrough spurs are very good, as are the white arrowmax with the three rings of holes.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-27-2014, 10:58 AM   #1348
Default Kimbrough spur gear for pan car dif
That would be these ones?
http://kimbroughracingproducts.com/s...egory_id=199#2
Old 04-27-2014, 11:01 AM   #1349
Pro10noob's Avatar
Yes
Regards Roy
l===/o\===l
Old 04-27-2014, 11:03 AM   #1350
Default Max teeth
Regards Roy
Oops me bad
I knew it was 78 or 81 for stock.
That would do the trick.
But what if mod is applicable? I'm asking because some say that over 81 can't be used in case of a small diametre of the tires.
