Old 08-10-2013, 06:26 PM   #1246
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Marc L. View Post
Another picture.
Yes! Another 10L is brought back to life! Looks good.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 08-11-2013, 10:38 PM   #1247
Grenade10's Avatar
Trader Rating: 37 (100%+)
Default Pro10 at Heart of America series race
Just got back home and thought I would do a quick recap.
We had two CRC cars and my Darkside, all cars made and finished all qualifiers, with progress made on each round. Best part was having races asking if we will be running at the next race, as thy have either WGT or older 235 car. So maybe 6+ cars next time, so here is the invite for all you closet racers.
I'll post more info, pictures in the next few days.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 08-12-2013, 01:37 AM   #1248
I found a Parma Intrepid GTP body at my lhs bargain box. I really would like to have an Andy's Jag GTP body.
RoyU is offline   Reply With Quote
Old 08-12-2013, 10:26 AM   #1249
Grenade10's Avatar
Picture from Lincoln
Old 08-12-2013, 10:28 AM   #1250
Grenade10's Avatar
Ok, so now with a picture.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-opening-weekend.jpg
Old 08-12-2013, 08:08 PM   #1251
NutDriver's Avatar
Trader Rating: 14 (100%+)
RoyU, Stormer Hobbies has the 235mm McAllister Jag GTP. They also have Parma re-pops of TOJ-type bodies.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 08-14-2013, 11:01 AM   #1252
bigblok427's Avatar
Default Camarillo
Here is a pic of our last outing in Camarillo full 10 car heats.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-235pan.jpg
bigblok427 is offline   Reply With Quote
Old 08-14-2013, 02:32 PM   #1253
spacendeman's Avatar
Send a message via MSN to spacendeman
Looks nice!
Last clubrace at the mach heemstede track in the netherlands we had 8 pancars at the starting line :-)
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 08-14-2013, 05:47 PM   #1254
hi!
what gear I should go when:
- 5.5T graupner very good engine (12.5mm rotor),
- 2S lipo,
- HW 2.1 120A speedo on 12AWG wires with modified software with
less turbo (no stock settings),
- rear tires around 60mm,
- medium grip with open asphalt track (1/10 nitro do ~20 sec lap or less).
Already has 75T/48p spur and thing abotu 20 pinion.
Regards!
m.
ps: car is 10L2 with nissan body
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-15-2013, 01:31 AM   #1255
tudor_47's Avatar
Originally Posted by M.Abramowicz View Post
hi!
- 2S lipo,
Regards!
m.
Try going smaller on the pinion..
I drive 77/13 or 77/15 in my car with a 4.0T motor.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 08-20-2013, 05:32 AM   #1256
Default GM Genius 120
No response on the GM Brushless thread.
Maybe I get lucky on this thread.....
Hi, bought me this one recently.
http://hk-modellbau.com/default.asp?...734&kat_id=298
Using it for Pro10 235mm outdoor asphalt.
motor Corally Red Series Delta 7T sensorless
Done some testing.
But what puzzles me is how to work option 11 Amp Limit (current drain limitation).
I hear and read all sort of things as to the preferred setting.
What setting best to use?
Is it: the less grip the tires have on the surface the lower the setting should be? Or not?
Do I have to take into consideration the amp draw of the motor?
Should the setting be equal or lower than the max Amp of the motor? Or not?
This is from the manual option 11 "AMP LIMIT"
"The current limitation can have an influence on the torque of the motor. AMP LIMIT should
be set so as to avoid that for instance the wheels of a car do not or only slightly grind on the ground."
This second sentence I don't understand. I think what is said here is that it's ones aim to avoid the wheels of the car to not or only slightly grind on the ground. I thought that it was a good thing that the wheels don't or just slightly grind on the ground. Because than there would be no wheelspin. Me no understand..... :-(
What is the influence of the amp limit on the torque of the motor?
Kensei is offline   Reply With Quote
Old 08-20-2013, 05:37 PM   #1257
Done some testing.
Limiting the current limits the torque, in the same way that limiting the voltage limits the rpm.
Stregone is offline   Reply With Quote
Old 08-20-2013, 07:54 PM   #1258
LonnyJ1950's Avatar
By limiting the amp draw, you limit the acceleration. If you have a lot of wheelspin, or the car is wagging from side to side out of the corner, you turn down the amp draw (lower number) to help eliminate this problem and make the car more controllable.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 08-23-2013, 09:53 AM   #1259
Default 10L2
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-552707_562313490496781_1287751138_n.jpg
balace L/R perfect!
Michal Abramowicz
Old 08-23-2013, 10:22 AM   #1260
Attachment 1104000
balace L/R perfect!
You stopped racing touringcars?
SEO by vBSEO 3.5.0
