Like Tree185Likes
Old 07-25-2013, 02:24 AM   #1231
Originally Posted by NutDriver View Post
Cap tires? Where?
Looking through the list of shops on the manufacturers website http://johnsbsrracing.com/cap-tires throws up Lefthander RC
terry.sc is offline   Reply With Quote
Old 07-25-2013, 08:00 AM   #1232
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Those are oval-style caps, the softest of which is still very hard. When "caps" were used in roadcourse/On-Road racing, they were generally more like and sometimes quite literally, "capping" a standard foam tire with a bicycle innertube, usually not even wrapping the rubber over the sidewall to give a very soft tire. It was popular technique for F1-rubber classes some two decades ago but I'm pretty certain they've closed that loophole in their rules by now.
MarkA is offline   Reply With Quote
Old 07-25-2013, 08:26 AM   #1233
You are talking about Tamiya tyre caps there, sold as a rubber sleeve you fitted over your foams. Great tyres in the wet, gave more grip in standing water than foams on a dry track, but not much good in the dry as they picked up any dust on the surface. Long since discontinued but they do pop up on ebay from time to time. Search for Tamiya 53090 or 53184.
Old 07-25-2013, 04:58 PM   #1234
NutDriver's Avatar
Trader Rating: 14 (100%+)
Now that you mention the Tamiya-type caps, I remember folks trying this with bicycle inner tubes. The BSR-type caps are one reason that I don't have an interest in oval racing. The indoor oval that was in Greenville, SC years ago would eat a set of caps in one night in the pro stock class. This was back in the days of 45* timing advance on 27t "stock" motors, so you'd destroy a $28 motor every race night, too. With entry fee, that's about $100 for 16 minutes of run time (12 minutes on some nights).....and that's in 1990's $!
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 07-27-2013, 12:47 AM   #1235
2wdrive's Avatar
I have no experience with them but I have read that BSR caps last quite a long time on normal surfaces like asphalt? They are quite expensive though so I don't know how the price vs wear is against foams (in oval).
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 07-27-2013, 09:21 AM   #1236
Moderator
MarkA's Avatar
It would vary a bit on the surface but the key to remember is that in Oval, you are quite literally grinding one side of your car into high-speed corners thousands of times a race day and they would often run staggered caps, meaning the outside tire is larger than the inside, so you just have to grin and bear it with replacing at least your right-hand tires very often. There's a reason interest in Oval is best described as "regionalized"....
Old 07-27-2013, 09:22 AM   #1237
spacendeman's Avatar
Send a message via MSN to spacendeman
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-20130725_200358.jpg
Almost done!
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 07-28-2013, 09:45 AM   #1238
1/8 IC Fan's Avatar
Trader Rating: 40 (100%+)
Wanted to share my Delta Villian. It is in as raced condition from back in the day. Was run as both an oval and a roadcourse car. Only optional piece is the Hyperdrive belt drive.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-imag4013.jpg
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 07-29-2013, 01:57 AM   #1239
2wdrive's Avatar
Cool car! I am not sure if I could work with no ride height adjustments
www.rc-lemans.de
Old 08-03-2013, 12:59 PM   #1240
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Not bad...you ever thought of converting it for brushless motor racing?
trackdesigner71 is offline   Reply With Quote
Old 08-05-2013, 02:18 PM   #1241
Marc L.'s Avatar
Thought you might like to see my current project. It is a graphite RC10L with a few new pieces. I installed the chassis brace from a fiberglass 10L2 and the object on top of the Rx is a $3 Turnigy voltage booster.
Enjoy!
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-image.jpg
Marc Lavoie
If you re-calculate your race results using the IOF (Index Of Fun), you can win every time! (Apologies to Howard Cano)
Marc L. is offline   Reply With Quote
Old 08-05-2013, 02:19 PM   #1242
Marc L.'s Avatar
Another picture.
Marc Lavoie
Old 08-05-2013, 02:23 PM   #1243
Marc L.'s Avatar
One more.
Also, I need to learn how to post pictures.
Marc Lavoie
Old 08-10-2013, 02:06 PM   #1244
1/8 IC Fan's Avatar
So finished the conversion to a Delta Villain IFS with NIP parts and an older set of Delta shocks from my Intimidator.
The ride height was not an issue back in the day when we ran caps. Also it will stay in the last run condition, aside from the IFS and displayed in a book case.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-imag4329.jpg   Pro 10: 235mm Le Mans Prototype Pan Car Discussion-imag4337.jpg
Old 08-10-2013, 02:37 PM   #1245
Wow that looks awesome!, nice work you got there.
Currently:
