Like Tree94Likes
Old 09-01-2012, 02:36 PM   #1006
2wdrive's Avatar
Do you mean inner tire tubes? Some drivers experimented with mountainbike inner tire tubes pulled over pro10 tires. It didn't give any traction.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 09-02-2012, 01:44 AM   #1007
NiMo's Avatar
Originally Posted by 2wdrive View Post
I like the alternative use for a plastic cup
NiMo is offline   Reply With Quote
Old 09-12-2012, 10:26 PM   #1008
Default 2s Roll outs
Hi all you Pro 10 racers, I am looking for some starting point roll outs for an 8.5t and 6.5t motors on 2s lipo.
Thanks for any help you can give me.
blackbird is offline   Reply With Quote
Old 09-13-2012, 12:49 AM   #1009
salze145's Avatar
Hello from Barcelona!
Here is my old RC10L2 with some L4 front pieces. Side dampers are a "home made" modification. I want to buy saddle lipos to improve weight distribution, but the car works well with a 10.5t sensored motor, 35A Team Powers ESC and 2S 4000 25C lipos.
some pics:
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-assorc10l2.jpg
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-assorc10l2_2.jpg
regards
salze145 is offline   Reply With Quote
Old 09-13-2012, 02:03 AM   #1010
2wdrive's Avatar
Hi, you have a RC10L (with epoxy chassis). http://www.petitrc.com/reglages/asso...10l_manual.pdf
Old 09-13-2012, 02:20 AM   #1011
salze145's Avatar
thanks for the info!
is recommended to change the epoxy chassis to carbon?
Old 09-13-2012, 02:44 AM   #1012
2wdrive's Avatar
On high traction tracks a carbon chassis will be more responsive than epoxy. On low traction tracks an epoxy chassis (more flexible) is more forgiving than a carbon chassis.
Old 09-13-2012, 02:46 AM   #1013
Joost K.'s Avatar
The epoxy chassis does has a lot of chassis-flex in it. Yes, it is reccomended to change to a carbon chassis.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 09-14-2012, 05:56 AM   #1014
Default Info
info which model should I choose? Corally 10x or Corally 10 SL? let me know thanks.
biagio23 is offline   Reply With Quote
Old 09-14-2012, 06:06 AM   #1015
2wdrive's Avatar
10SL is the newer model and won the German Masters Pro10 a few weeks ago. http://www.corally.de/default.asp?ex...n.asp&navid=42 Go for the 10SL.
Old 09-16-2012, 02:25 AM   #1016
Default 3Racing Tyre Truer
I'm planning on buying this one:
http://rcmarket.com.hk/product_info....oducts_id=6112
Does anybody know which wheeladapter goes with it for Corally 10SL?
Kensei is offline   Reply With Quote
Old 09-16-2012, 10:38 AM   #1017
Pro10noob's Avatar
Use the original from Corally.
It will fit perfectly.
At least it did with mine.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-16-2012, 01:12 PM   #1018
teamedgerc's Avatar
Location: AL, FL, IL, GA, MO, Canada due to race track locations and time there:)
2wdrive! We've used 20x1.75 tubes cut and then buffed down to cap our 12th scale tires we run on our rc karts for many years now. My guess is about 8 yrs and on going. Some use the tubes/caps for only fronts, some all the way around. They also work perfect on carpet if they allow rubber or a group of kart drivers want to change things up and make it more challenging for everyone. We use a simple tire glue to keep them on nicely.....
Robert
Team Edge RC
techsupport@teamedgerc.com
teamedgerc.com
"Where speed and skill meet"
* Team Edge RC * Reedy * BRP Kart Racing * TM Racing * RBP * Novak * Hobby Wing *
teamedgerc is offline   Reply With Quote
Old 09-17-2012, 12:27 AM   #1019
regards Roy
HUDY arbor truer adapter for 1/10-1/12 (the newest one) also works perfect.
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 09-21-2012, 03:53 AM   #1020
salze145's Avatar
anyone knows these old wheels? I have the opportunity to buy several new lots of them. The seller says that these wheels are for PRO10...
champion tires
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-p9210078.jpg
RGT R2 pro 10.5t - M05 pro mabuchi - TT02 13.5t - Vintage Asso RC10L
