Like Tree92Likes
Old 08-07-2012, 09:39 PM   #991
Originally Posted by spence88mph View Post
So I took my RC10LS to the track after not driving a pan car for a good 10 years, anyway traction was very low, track was very dusty. Car is running a 6.5T, everytime I throttled a but of power, like 40% it would snap left very hard. I loosened the diff, this helped a little but it would still do it. I got used to driving the car around at very low speed and it turned in quite well but any time i gave it a little throttle it would just turn very abruptly. Any ideas? I think it might be something with the diff... I ended up having quite a crash chasing my friend's TC, I damaged the NOS carbon chassis, broke a servo mount, de laminated a bit I will glue and clamp it....
After my car was dead I drive his TC, they are so forgiving! Very easy to drive on a low traction track.
try to make the central dumper extremely soft, using some 20WT oil, but be sure the chassis is not touching the ground. be sure there is some 5-10mm "fall" of the rear end while you take your car up from the ground.. the rear end has to work..
www.rc2wd.cz
www.lemans-serie.cz
www.corally.cz
Team Corally
TroubleRK is offline   Reply With Quote
Old 08-08-2012, 01:58 AM   #992
2wdrive's Avatar
Coooool, you should sell them!
These are 3mm 7075 t6 aluminium. The original L2 podplate is 2.2mm thick. The original podplates have a tendency to bend more easy. I had a L2 podplate bend last weekend. (not sure how long it was bend, maybe i have driven a couple of races with it but found out on monday after dissasembling the pod).
They will be for sale through an online shop once the podplate is final. It will not be long.
Just something for the T-bar loving crowd
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 08-08-2012, 02:57 AM   #993
Thanks a lot for the info, I have noticed I can't get any droop out of the pod, I think my T-bar must be really think. It is the stock one that came with the kit. I also think I need to spend some time balancing the car, I will stick with trying to dial it in. A few friends at the track were saying the 6.5 is just too much for that old car, shame on them!
2wdrive - Cool, do you have an online store or on someone elses?
THEBIGBULL - PM sent, thanks!
spence88mph is offline   Reply With Quote
Old 08-08-2012, 08:49 PM   #994
Hey 88, I didn't receive your pm, try it again or email me at tpick@shaw.ca
Be Kool
TJ
THEBIGBULL is offline   Reply With Quote
Old 08-13-2012, 01:58 PM   #995
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Default Dusty days doin' donuts
The RC10LSS wide hooked up pretty good ........until the tires filled with the evil red paint dust. Then it was donut time. We are concerned that if we sweep the track the broom will cause more of the paint to separate from the asphalt surface of the outdoor basketball court that we use making it an even worst situation. Perhaps using a leaf blower?? no water is available to wash the track.
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Cancun Tom is offline   Reply With Quote
Old 08-13-2012, 02:57 PM   #996
LonnyJ1950's Avatar
A heavy duty commercial blower will do the job, though it might also erode the paint a little. It's much better than sweeping. It is also a hot, dirty job that requires ear plugs and possibly a face mask. I used the plugs, but not the mask, depends on sensitive you are to the dust. Start at one end and work toward the other.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 08-15-2012, 05:57 AM   #997
Hi!
Maybe stupid but why not ask?
I just put fluid cs competition grip (this thicker one) on pro10 lilacs tires (spec ones) for ~16h, tires put to bag for night.
Now next day foams are very nice, under finger are more nice then same tire/compund with markus mobers foam fluid 30min.
Now what I think and maybe want.
In my 200mm pan car with sophia body (rules like wgt), tires with markus mobers start working bad when they "over soaked". It looks like rear end has too much grip or something like that, must drive few times on dusty place
Question is, tires prepared with another fluid can be better? few sets for all event, just take them from bag and put on car?
Just thinking, same tricks do drivers when can do with 1/8th nitro on road scale put thicker fluid on foam day before ...
Also I think about small machine like capricorn to made soaking tires better
Regards and sorry for that stupidyty
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-15-2012, 07:45 AM   #998
2wdrive's Avatar
pre soaking has it merrits but what if it rains on race day? The tires will be more or less useless when they get soaked too long in a bag.
We don't wear the tires in one go like they do in 1/8 scale so any additive that is still in the tires will degrade the foam further.
Tuning on the spot is not possible either.
Best thing to do is to find out how much you need to soak before it wears off during the run. Anything more is wasted and will degrade the natural rubber in the foam even more then usual. Degraded/soft foam is more wear and less traction when re-using the same tires.
At least that is my experience.
www.rc-lemans.de
Old 08-15-2012, 03:08 PM   #999
Thank you for answer.
I will just prepare one set of jacos/lilacs + bsr lilacs for rear end.
Then I will try it.
If rain I usually no race, there is no roof for drivers so need 2nd one with umbrella
Regards!
michal
Michal Abramowicz
Old 08-27-2012, 03:29 AM   #1000
V12
V12's Avatar
German pancar nationals just been held last weekend. Here you can see a video from the 3rd leg of A-Mains http://www.youtube.com/watch?v=tXmsQcyav-U
Fastest laptimes are about 0.5s faster than 1/8th cars track record. Motors are either 4T or 4.5T or 6 - 7T delta wind and 2S battery of course. Data logging from one car is showing about 90.000 rpm from the motor at max. speed what equals to about 140 km/h.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 08-27-2012, 04:39 AM   #1001
2wdrive's Avatar
awesome.........42 pro10 drivers! Wish i could have been there....
instead i had a race in the WET with a handfull of drivers.
www.rc-lemans.de
Old 08-27-2012, 07:08 AM   #1002
tudor_47's Avatar
I wish it was possible to get hold of the tires, I guess it is rubbers?
The motor is that sensorless? what brand and turn/Kv?
Thanks!
Johnny, from an all to often wet Ostersund in Sweden
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 08-27-2012, 11:06 PM   #1003
2wdrive's Avatar
The wheels are tamiya caps on pro10 tires.
I use a corally red line sensorless 13.5t and a fake ezrun 60A esc. Others use 10.5t. My ride height is 10+mm.
www.rc-lemans.de
Old 08-28-2012, 03:42 AM   #1004
tudor_47's Avatar
Thanks!
Old 09-01-2012, 07:33 AM   #1005
Taz_S's Avatar
I have read in the 1/10 pancar thread years ago that someone tried it out and that they didn't work. The rubber on those BSR capped tires is a harder kind of rubber designed for dry asphalt. It is not the same rubber as the Tamiya caps that are very soft and specially suited for the rain.
you ever try bike tubs. My old friend make what was cal torpedo tubs for dirt oval. They might work also and if they do you spend about 5 but for 20 tires worth.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
