Like Tree39Likes
Old 07-19-2012, 06:44 PM   #946
hacking gt car based on 10R5/10L2/12L4 parts
http://www.moosi-masters.com/viewtopic.php?f=5&t=2706
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-23-2012, 04:20 PM   #947
Default Nissan GTP
Is this bodyshell allowed in Holland?
http://www.corally.de/default.asp?ex...404&kat_id=964
Kensei is offline   Reply With Quote
Old 07-23-2012, 04:22 PM   #948
Joost K.'s Avatar
Yes it is!
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 07-25-2012, 03:50 PM   #949
i tried it
good straight line speed but no steering even less than the 962 serpent
need to adapt set up to get some high speed steering
(i race mod with a speedline chassis)
closs is offline   Reply With Quote
Old 07-25-2012, 06:09 PM   #950
LonnyJ1950's Avatar
What body do you run?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 07-26-2012, 04:52 AM   #951
2wdrive's Avatar
Hi Closs, just out of curiousity. I was told the Speedline is 230mm at the front. I wanted to buy the Nissan GTP for a car with a 227mm front width but didn't when i heard the body was 225mm at the front. How did you get that nissan on? Is that body actually 230mm or wider at the front?
The flat pieces behind the front wheel arches and back wheel arches can be cut open as extra tuning options. Did you experiment with that by any chance?
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 07-26-2012, 09:01 AM   #952
Originally Posted by closs View Post
i tried it
In which way did you adapt the set up to tackle the high speed steering problem?
BTW: needed for mod racing with Corally 10SL, LiPo-config as in the kit.
(and yes I know there are lots of "buttons" that can be dialed, but I am interested in which ones you "fiddled" with ;-)
Old 07-26-2012, 12:32 PM   #953
racerx1920's Avatar
Trader Rating: 206 (100%+)
where can i get one of these cars i want one
Desoto Racing / Serpent America / ProOne RC
Serpent 748 / Serpent s120LTR
Dunn Graphics
1/8th Scale Racers of Toledo
https://www.facebook.com/DunnGraphics1
racerx1920 is online now   Reply With Quote
Old 07-26-2012, 12:55 PM   #954
Pro10noob's Avatar
How good are you with autocad?
Kidding.
Serpent S100 with extension kit makes it 235MM
Xray X10 with a extensionkit from Nitrosisters makes it 235MM
Asso RC10L2 the last of the 235MM cars from Associated
Corally SL10 200 and 235MM wide.
RCdevil, beautyfull car but a real attack on your wallet
Those are just a few.
You could also design one yourself like Joost K did.
I am running that car also and it is a pleasure to drive.
regards Roy
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-p235-ready.jpg
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-26-2012, 04:32 PM   #955
the MIX nissan fits easy as it is pretty wide up front havent used the hole yet
but understeer was so bad i stopped using it pretty quickly
i do plan to try it again as well as the 962 to get more straight line speed and better runtime on fast track
plan is to run the battery in the center and inline front axel with those bodies
i'm used to the mix lola wich gives tons of steering but has lots of aerodrag
for the guy asking what to do for better high speed steering
go inline at the front and go harder in the side tubes also set reactive camber to 10
but the body plays a huge part at speed on a pro 10
moving the body forward also help as wel as do harder tires at the back
Old 07-26-2012, 04:37 PM   #956
Old 07-28-2012, 02:36 AM   #957
I was just wondering where you could buy the irs rear axle from. I was also wondering when you were going to restock the widening kit for the front end.
colin
Originally Posted by tudor_47 View Post
Our 235mm rear end conversion for the Xray X10 is now ready and tested.
Gives a very stable and quick car.
pictures on our site. Lajf Racing www.lajf.se
It will soon be in our shop.
colin storey is offline   Reply With Quote
Old 07-28-2012, 02:54 AM   #958
Joost K.'s Avatar
You can buy the IRS rear axle directly from IRS if you want...
Old 07-28-2012, 03:39 AM   #959
http://www.youtube.com/watch?v=N4Qif...&feature=g-upl
MatsNorway is offline   Reply With Quote
Old 07-28-2012, 02:52 PM   #960
2wdrive's Avatar
can you explain what the different colors and lines mean?
www.rc-lemans.de
