Like Tree185Likes
Old 07-02-2012, 08:38 AM   #901
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Default Tires
Yes they are BSR caps. I bought a lot of 40 from a racer on Ebay.
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Last edited by Cancun Tom; 07-02-2012 at 08:47 AM. Reason: Sentence structure and first photo changed
Cancun Tom is online now   Reply With Quote
Old 07-02-2012, 08:55 AM   #902
What kind of surface do you race on? How does the cap tires perform on the surface you race on?
Also, how long do they last?
RoyU is offline   Reply With Quote
Old 07-02-2012, 08:55 AM   #903
Pro10noob's Avatar
What wide are those tires?
This as i am looking for some rain tires and caped tires work great for that.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-02-2012, 10:52 AM   #904
2wdrive's Avatar
Last weekend was the Benelux race. Sadly this year the event had less drivers enlisted in TC 17.5t boosted, TC 13.5t cirtix, TC 10.5t blinky and pro10 stock class. The pro10 modified was as strong as always (RC Lemans) with 20 drivers. There were 7 pro10 stock drivers.
A vollunteer had brought his Corally C10 for some practise laps in the evening. Sadly we could not persuade him to join the race even though his laps looked good.... .Hopefully we got more people excited for next year as there was some more interest for the pro10.
It was very sunny and warm on friday and saterday but on sunday afternoon we got rain which reshuffled the cards again.
Random pictures of the Benelux race. Most pictures by Orfeo and some of mine.
Podium modified pro10
Podium stock pro10
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 07-02-2012, 11:16 AM   #905
Cancun Tom's Avatar
Default Your pictures
WoW! An absolute bonanza of pictures. Thanks for posting them. I noticed on of the chassis had the weirdest tires I've never seen before. They were segmented donuts, 3 on each rear rim and 2 on each front rim. Do you know anything at all about them? Do tell.
Old 07-02-2012, 11:32 AM   #906
wingracer's Avatar
Trader Rating: 22 (100%+)
Those are rain tires. I've never seen pan car versions of them before but I have seen them for 1/8th nitro. I think Kissling makes them.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-02-2012, 11:36 AM   #907
Pro10noob's Avatar
@Wingracer....Your right.
Those are Kissling rain tires for Pro10.
You can only use them in the full wet.
If it is drying up, you distroy the tires.
regards Roy
l===/o\===l
Old 07-02-2012, 11:47 AM   #908
Cancun Tom's Avatar
Default Track surface
We race in only 1 location. It is a outdoor basketball court. It is asphalt that is smooth. It is painted with some kind of orange/red paint that is somewhat deteriorating due to the climate. It is unused as it was built in a new area of Cancun that had not yet been fully developed. Traction wise I think it's pretty good. However it does get dusty and we found that sweeping it tends to remove more of the paint and we don't want to go there. I've bought a leaf blower and we plan to just blow it off before each heat in the future. I'll attach a couple of pictures of it. We only race a GT class of 4WD touring cars and they have no problem hooking up to the track. The F1 open wheel cars do have a traction problem with a lot of loops occurring when too much throttle is applied. My Pro10 235mm RC10L is a work in progress and I'm still trying to find the handle on it. I'm the only one that has one so far. So that means I don't have any one to compare setups with. We race all year long outdoors because our weather allows it.
The capped tires on the Pro10 are the way to go here. Our track temp is around 150F. I use Gravity L! and L2 traction juice. The TC3's we use HPI rubber tires but aren't allowed to use juice on them.
Old 07-02-2012, 12:19 PM   #909
Very nice photos from pro10 Benelux race!!!!
We had our "Catalunya regional" pro10 race yesterday here in Spain. We are very few, only six people compared with twenty people with touring cars but we had more fun!!!
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 07-02-2012, 01:44 PM   #910
2wdrive's Avatar
@cancun
One of the 6 circuits we have our nationals on is a basketball/tenniscourt. It has the same kind of red asfalt.
We tried all kinds of stuff but Corally Asphalt Jack is the only things that works well on that track with foam tires. It is thick as maple syrup so massage it in the tires and let soak for an houre. It works better with tirewarmers as the heat makes the syrup thinner and soaks more in the tires.
As you can see in the video it is quite weatherd red asphalt. We drive with 235mm 10.5t 2s boosted on that circuit. It feels more like 1/12 as the track is small and we go very fast . On that track we use double pink backtires and lilac or purple front and we have plenty of traction. Traction does fade a little in 7 minutes though but it is still very driveble. Try it out, it might work for you.
+ YouTube Video
www.rc-lemans.de
Old 07-02-2012, 11:14 PM   #911
regards Roy
Made them myself a couple of times as well, just make grooves on a foam tyre, and use a rubber band to keep the cap in the groove while the glue is drying.
Tamiya TRF101, Corally F1 SL, 3Racing F1-09, Kyosho Mini-Z MR03, Corally SP12M, Tamiya SuperShot, Kyosho Optima Pro, Duratrax Vendetta.
Home track: http://www.amcaracing.nl
ijdod is offline   Reply With Quote
Old 07-03-2012, 12:15 AM   #912
Pro10noob's Avatar
What did you use?
Tamiya tire caps or just a inner tube for a tire?
regards Roy
l===/o\===l
Old 07-03-2012, 12:33 AM   #913
Joost K.'s Avatar
These are my rain tires which I made a couple of weeks ago. I still have to find the time to make the fronts but the rear tires turned out pretty nice.
I used Xceed foams and Tamiya Tire-Caps.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 07-03-2012, 12:33 AM   #914
2wdrive's Avatar
regards Roy
I have read in the 1/10 pancar thread years ago that someone tried it out and that they didn't work. The rubber on those BSR capped tires is a harder kind of rubber designed for dry asphalt. It is not the same rubber as the Tamiya caps that are very soft and specially suited for the rain.
www.rc-lemans.de
Old 07-03-2012, 03:54 AM   #915
What did you use?
regards Roy
Tamiya caps.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
