Like Tree185Likes
Old 03-28-2012, 03:35 PM   #691
LonnyJ1950's Avatar
You see them more in 1/12TH than Pro-10. They use a strip of firmer compound rubber at the outside edge of the wheel to prevent the sidewall from folding over under the pressure of cornering. The most common is a Yellow compound tire with a strip of Gray at the edge.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 03-28-2012, 04:59 PM   #692
Thanks. I figured it would only be of some niche use.
Now I have another question. I am finally getting around to installing the 235mm widening kit on my crc gen x le, and I have no idea what to do. Like I have said I got the car used and it isn't completely stock. It has the lay down servo mount which looks like it changes how I mount the front of the widening kit. it doesn't help that there are no instructions that I can find anywhere online
Stregone is offline   Reply With Quote
Old 03-28-2012, 09:53 PM   #693
Default RCdevil 235mm pan car
Hey all.
It is with much regret that I am having to sell my near new RCdevil PC10H3X 235mm pro10 car chassis. It is to be sold with a small mountain of spares and the whole lot will be sold at nearly half the price of the new car kit. It has only done one race meeting and is in near perfect condition. Any and all interested in the car please send me a pm. Kind regards, Glen.
Bumpy is offline   Reply With Quote
Old 03-28-2012, 10:07 PM   #694
tudor_47's Avatar
Manual at CRC web : http://teamcrc.com/crc/downloads/man...0LE_manual.pdf
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 03-29-2012, 12:29 AM   #695
No one knows about the Xceed additive?
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 03-29-2012, 02:10 AM   #696
I have it, tf1, tf2, wait for tf3.
But for asphalt -> sun lotion
For carpet -> markus mobers
I think I lost some money ...
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-29-2012, 03:25 AM   #697
Hi m8,
I tried the TF1 and 2, I like the TF-1. Works pretty well, the TF-2 lacks grip.
I heard the TF-3 gives some more grip than the 1, its on its way here but I dont have it yet. Its also supposed to be more agressive on the tire so I hope it wont make em chunk easily.
Before I allways ran CS high grip and this is about the same. My problem with the CS stuff is that my LH seems to be doing months over his order and the xceed stuff is in stock at RC market...
Greetz
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 03-29-2012, 07:03 AM   #698
I have ordered TF-1 low grip. Letīs see how works
Quante, that Q10 car is very nice!!! I like that double wishbone front system!!!
I have seen similar concept cars at www.rcpancar.se maybe same car..
I have a friend with a Calandra Stranahan car, but i think they donīt exist anymore...
Old 03-29-2012, 07:41 AM   #699
2wdrive's Avatar
Cool, didn't know about that site. I see my old body in the gallery section!
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 03-29-2012, 11:37 AM   #700
Hehehe, thanks, it is a very nice car indeed and I still have it standing here.
Ran extremely great as well but the lack of time to do testing has driven me to a Corally 10SL since last year.
But I still plan to reput the electronics in because the car has way more mechanical grip than any other pancar I've had.
Old 03-29-2012, 01:00 PM   #701
Pro10noob's Avatar
You got pic's of the car Quante?
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-29-2012, 01:45 PM   #702
regards Roy
http://home.scarlet.be/~dq312531
Look for Q10
Old 03-29-2012, 02:30 PM   #703
NiMo's Avatar
I like that rear end.
I had visions similar to that for an idea to use on the rear of an F1 car (using Tamiya GT01 front parts) but I never put it to practice.
I may just have to look at my idea again now I've seen yours
NiMo is offline   Reply With Quote
Old 03-31-2012, 02:01 AM   #704
Joost K.'s Avatar
Very nice indeed! My body is also there in the gallery and also a lot of MACH pictures!
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 04-04-2012, 10:28 PM   #705
MrChodes's Avatar
What am I doing wrong? Every so often after a diff rebuild I damage my spur as per photos. Tends to happen fast, ie during first run.
I always use 3racing spurs. Steel balls used for this build. They usually last well. Last spur probably did 10-15 runs before motor moved after a big bump and it got chewed by the pinion. The ball holes still looked OK.
Serpent S100. Ducati FM1-e bike.
MrChodes is offline   Reply With Quote
