Old 01-08-2012, 02:02 AM   #526
Default I designed new pod.
I designed new pod.
New pod is 10mm wider then original pod.
It removed axle shim.
All chassis made 3T carbon.
but wider bulkhead shaft is not making, yet.
I think, It will make next weekend and try to run.
I hope, It will good run.
Thanks guys for help.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-img_9701.jpg   Pro 10: 235mm Le Mans Prototype Pan Car Discussion-img_9705.jpg   Pro 10: 235mm Le Mans Prototype Pan Car Discussion-img_9681.jpg   Pro 10: 235mm Le Mans Prototype Pan Car Discussion-img_9688.jpg
Hoon Sung is offline   Reply With Quote
Old 01-09-2012, 01:14 AM   #527
westy1969's Avatar
A nice and quick job! well done
CRC Gen-X 10 200mm indoor-setup | CRC PX10W full 235mm
westy1969 is offline   Reply With Quote
Old 01-09-2012, 01:58 AM   #528
2wdrive's Avatar
looks good. With 3mm carbon that car will be quite durable. Did you make that clamp hub yourself? It looks longer then the clamp hubs from IRS.
I can't see it clearly but it seems you use a pinion with teeth where the edges are not 90 degrees. They seem to have a 45 degree angle going towards the top? I have bought similar 48dp pinions before but don't use them anymore as i found they damaged the spurs. I changed them to a normal 48dp pinion with straight teeth and the problem was gone.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 01-09-2012, 09:18 PM   #529
Default Thanks~
Thanks guys.
I'm very exciting bacause I will drive on saturday.
anyway..
The left clamp hub is IRS. (IRS220)
It not include 235mm axle set.
I didn't use the pinoin on the picture.
It use on Yokomo R12(1/12) that 64P
I'm using 90 degrees pinion 48P on 2s lipo pro 10.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-irs220.jpg
Old 01-10-2012, 05:38 PM   #530
tallyrc's Avatar
oh the things i'd do if i owned a cnc mill...
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 01-11-2012, 05:11 AM   #531
Send a message via ICQ to ses414
my humble RC10L2.
10.5T, 60A esc
Exceed F(hard) R(soft)
48P 81t/20t
3s2p4400mah lipo.
ses414 is offline   Reply With Quote
Old 01-11-2012, 05:18 AM   #532
Pro10noob's Avatar
@SES414...
Your going for a LAFB???
That car would be flying
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-11-2012, 08:00 AM   #533
@Pro10noob
Thanks for the compliment.
Tried the car at my local nitro track, not as fast as the 1/8th but did not get lapped by them in 7min. This beast has potential! Just brand new tyres and no tyre sauce.
Old 01-16-2012, 03:46 PM   #534
To keep the tread alive, this vid though 2 years old is awesome.
Especially like the yellow car waiting for the car he's chasing to recover from the incident, true gentleman racing!
http://www.youtube.com/watch?v=A8ivIhZGjFg
spence88mph is offline   Reply With Quote
Old 01-16-2012, 03:52 PM   #535
Joost K.'s Avatar
Ahhh... These are our German Pro10 friends driving Pro10 chassis with modified motors. We are talking about 6 turns Delta in there!!!
They race with a very high fun & friendship factor as was seen in this movieclip...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 01-17-2012, 01:16 AM   #536
2wdrive's Avatar
From all the mod video's this one is my favourite.
http://www.youtube.com/watch?v=Ub6fLXI9m6A
Watch as they go past the driverstand full speed and seem to go straight into the wall at the end but steer into the tight turn at the last milisecond. That is some good driving there.
www.rc-lemans.de
Old 01-17-2012, 12:58 PM   #537
Default Does anyone know Freddy Smolik?
Hey guys. Im trying to get in touch with Freddy Smolik from Rcdevil. Just received my new PC10H3X 235mm pan car chassis from him and there's NO shocks with it. I've sent him a few emails now with no response and need the shocks to run the car in my National champs in just over a weeks time down here in New Zealand of which im the current No.1. Would really like to retain my title but cant do it without shocks. Any help would be much appreciated.
Bumpy is offline   Reply With Quote
Old 01-17-2012, 01:29 PM   #538
2wdrive's Avatar
That is a real pita. How many days are you already waiting for a reply? Even if they send it tommorow i am not sure you will get the shocks on time. Better prepare the old chassis to be sure.
I will see if i can contact him on this side of the pond
www.rc-lemans.de
Old 01-17-2012, 08:51 PM   #539
I've emailed him twice since Sunday with no reply so far. Unfortunately I sold the old chassis to buy the Rcdevil chassis so am really hoping the shocks will get to me or I will not be racing at all.
Old 01-18-2012, 01:19 AM   #540
You could try some Associated RC18 shocks. The earlier prototypes used AE shocks.
Der Dicke is offline   Reply With Quote
SEO by vBSEO 3.5.0
