Like Tree85Likes
Old 12-13-2011, 05:42 AM   #481
Pro10noob's Avatar
BSR supplies capped tires at $80US a set
These are also in different shores front and rear.
If your onlucky and rip a set to pieces then it will be a costly day.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 12-13-2011, 06:01 AM   #482
2wdrive's Avatar
Originally Posted by rokosam View Post
No way we can run after touring guys. In a democracy majority rule...
One hour before means waking up at 6:00 AM!!!
I have proved to apply additive at home and to get the tires ready for the race the night before racing but I think this makes the tires softer with time and unusable...
Yeah, you can throw the tires away after that, they will get softer and stay that way.
Democracy rules but a little giving and taking/understanding for another group so they can have a good time as well is another matter. Anyway...sure way to kill a class imo.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 12-13-2011, 06:40 AM   #483
nrtv20's Avatar
We used to cover foam tires with a silicone layer for running on smooth indoor cement; it worked great. I never tried a pan car like this but we did do it on 1/10 gas on-road cars and 1/10 offroad trucks; I still have a set for running on the street that havenít peeled in 10 years! (I donít run it much but the silicone is still there non the less) I donít remember what brand it was but there was a few that would last forever and give great traction. Thatís something to try if you have an old set of tires laying around.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 12-13-2011, 06:44 AM   #484
80 USD?, Iīve seen them cheaper than ordinary pro10 foams!!!
8 USD the unit. Total 32 USD
http://www.windtunnelracingproducts....acturers_id=53
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 12-13-2011, 06:57 AM   #485
tudor_47's Avatar
This was interesting.... rubber pancar wheels....
will they work on wet asphalt? outdoors..
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-13-2011, 06:26 PM   #486
LonnyJ1950's Avatar
Capped tires generally give less grip than a good foam. They also have to be warmed up to work properly. They might be a solution if your track is always dirty.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-14-2011, 12:21 AM   #487
Pro10noob's Avatar
Have you ever driven capped tires in the rain?
The grip is even better then when running foams
regards Roy
l===/o\===l
Old 12-14-2011, 01:46 AM   #488
I thought you use special rain tires for rainy conditions
Old 12-14-2011, 02:01 AM   #489
Pro10noob's Avatar
For Pro10 the word is out that the Kissling tires are the best.
Pehaps the BRS capped tires are also good.
When driving a TC on rubber and it is raining you have good grip.
It is the inbetween dry and wet that is tricky.
regards Roy
l===/o\===l
Old 12-14-2011, 02:40 AM   #490
2wdrive's Avatar
In the rainy conditions the tamiya caps on pro10 tires work very well but the caps are long gone and only a few stores have them somewhere in the basement if your lucky. They don't need full wet conditions to work but the more it rains the better they work.
The Kissling tires are rain tires that only work in full wet conditions with a layer of water on the circuit. Anything else and they degrade very easy and won't work good what i have heard from M7H.
It depends on the rubber that bsr is using on their oval capped tires. I am not sure if it is the sort of soft rubber that we want in the rain as the rubber in dry conditions is usually harder. It is purely an assumption on my part.
The video is already posted but pro10holland proved that racing in the rain is a lot of fun and really works very well with tamiya caps.
http://www.youtube.com/watch?v=InQsAw8htkY
(inserting youtube doesn't seem to work anymore?)
www.rc-lemans.de
Old 12-14-2011, 06:38 AM   #491
2wdrive's Avatar
What silicone did you use for that?
www.rc-lemans.de
Old 12-23-2011, 04:34 AM   #492
TJames987's Avatar
Trader Rating: 10 (92%+)
Default body
which pro10 body generates the best grip for an fast open parking lot track?
thx
TJames987 is offline   Reply With Quote
Old 12-23-2011, 05:43 AM   #493
Pro10noob's Avatar
Try the Nissan P35 or the Peugeot 905HD.
regards Roy
l===/o\===l
Old 12-27-2011, 06:41 PM   #494
Do you guys put anything on the bottom of your chassis to protect them from scratches? I have an almost new RC10LS chassis and I want to keep it nice as they're not easy to come by!
2wdrive, is your top pod plate an off the shelf item or did you have it made? I would really like to buy one! I really dig your car, I stare at this picture a lot for ideas!
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-100_0379.jpg
spence88mph is offline   Reply With Quote
Old 12-27-2011, 07:09 PM   #495
Does anybody run this class around tampa,fl these things look wicked
rickybobbyxxx is offline   Reply With Quote
