Like Tree185Likes
Old 11-23-2011, 09:48 PM   #436
Pro10noob's Avatar
I want your avatar
Originally Posted by LonnyJ1950 View Post
I want one, I want one.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-23-2011, 10:32 PM   #437
LonnyJ1950's Avatar
Go to the Ultimate Car Page:
http://www.ultimatecarpage.com/car/304/Mazda-787B.html
Mazdas and more!!
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 11-23-2011, 10:38 PM   #438
Pro10noob's Avatar
Yeah but not in 200 or 235MM
regards Roy
Mazdas and more!!
l===/o\===l
Old 11-23-2011, 11:12 PM   #439
LonnyJ1950's Avatar
I believe Tamiya made one, but good luck finding one.
Tamiya Mazda 787b
Lonny
Old 11-23-2011, 11:35 PM   #440
Pro10noob's Avatar
They did indeed and sometimes you see them pop up at e-bay but for rediculous prices.
regards Roy
l===/o\===l
Old 11-24-2011, 05:05 PM   #441
LOW ET's Avatar
Trader Rating: 94 (100%+)
anyone have info on what's needed to install the irs axle kit in a rc10l2? does it go together like the stock rc10l2 axle or like a crc, etc...? do i need axle spacers or is it the correct size to not need spacers? does it use a diff thrust cone and belleville washers, etc...? is the spur bearing a flanged bearing?
LOW ET is offline   Reply With Quote
Old 11-25-2011, 12:24 AM   #442
2wdrive's Avatar
With the IRS axle you only uses an axle spacer on the left side where the clamping hub is (like in the manual). If you have the long clamping hub it should be a direct fit.
If you don't have the axle spacer look the number up in the L2 manual. They are still availlable.
You can use extra washers to space the wheels evenly but it seems pretty spot on.
Originaly the L2 came with a diff thruts cone and bellivile washers but i don't really like them. As the hole inside the washers is bigger then the axle they never seem to sit 100% ontop of eachother and it seems that the pressure on the ballbearing is not even then. The diff action was only good after a few tries to let the washers sit more even on eachother. The washers also flatten after a while. Maybe others have other opinion on the washers or maybe i did something wrong.
I tossed them out and tried a more simpler solution. I use an axle spacer that came with the kit with the nylon locknut and that is it. It is very smooth and easy. It is not high tech but it is really very consistent. Just be sure to screw the locknut on the axle as straight as possible. After a days racing just uncrew the locknut so the presure is off the ballbearing.
When the diff still feels gritty after a rebuild put a new bearing in (or swap the bearings in the diff hub around) and it feels very smooth again. Only if you get hit against teh axle the diff can get gritty, when not it will stay good for several races.
I am the only one in our group that is doing it this way. The rest is using the slapmaster etc. I can say that my diff feels as good as someone elses with a slapmaster. That said... the diff in the corally cars are always better
You can use a flanged bearing in the spur but i think the flang is maybe little to thick. I got better feeling with a non-flanged bearing and a thin washer (to allign the bearing better in the spur).
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 11-30-2011, 10:32 PM   #443
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Will this CRC kit fit on the RC10R5?
https://www.ssl-stormerhobbies.com/c...=ns&pn=CRC1711
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 12-01-2011, 12:28 AM   #444
tudor_47's Avatar
The rear hubs will fit, I used the hubs on my X10 during the summer.
Front, I do not know.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-05-2011, 11:02 AM   #445
Default Team Associated RC10R5
Originally Posted by Bumpy View Post
To start with, what chassis do you have? I just got the IRS wide pod axle set for my 10r5 and it works great. I just had to shim the diff side out 4mm between the diff and pod bearing and get a 15mm st/st tube spacer made to go on the other side with the standard clamping hub. Works a treat. now just waiting for my front widening parts to come in from Full Option.
On another note has anyone used the McAllister Pro10 body as listed on Stormerhobbies. https://www.ssl-stormerhobbies.com/c...c=cs&pn=MCA146
Hi Bumpy,
What IRS part numbers exactly? (because you refer to "set")
I mean not just the axle.
What shims to use? (how many, kind of material and so on)
Tube spacer is home made, or is it an original AE part?
What does "st/st" mean?
Thanks.
Best Regards,
Ken Sei
Kensei is offline   Reply With Quote
Old 12-06-2011, 02:02 AM   #446
Originally Posted by Kensei View Post
Hi Bumpy,
What IRS part numbers exactly? (because you refer to "set")http://teamirsrc.com/index.php?main_page=product_info&cPath=3&products_ id=59. Go into the 'Axles and Axle kits' section and you will find the '1/10th graphite pro axle kit - blue'. Thats the one I bought.
What shims to use? (how many, kind of material and so on)http://www.amainhobbies.com/product_info.php/cPath/1576_699/products_id/35065/n/XRAY-Aluminum-Rear-Track-Adjustment-Shims-05mm-10mm-20mm
Tube spacer is home made, or is it an original AE part?The 15mm long tube spacer was machined up by an engineer friend of mine
What does "st/st" mean?Stainless Steel
Thanks.
Best Regards,
Ken Sei
Hope the links work.
Bumpy is offline   Reply With Quote
Old 12-06-2011, 05:04 AM   #447
drbelleville's Avatar
Originally Posted by 2wdrive View Post
i think the protoform nissan p35 is the same as the Nissan P35 from corally. Corally probably re-used that mold or something.
+1 Corally and Academy cloned the Protoform P35. Protoform had destroyed the mold years ago.
D-Drive has 2 versions of the P35 on their site:
the 200mm P35 "Eagle"
the lightweight P35 "Protoform"
R/C'ing since 1982, Pro-10 racing in Germany and Italy in the early 90's, Keil DTM Cup.
The Pro-10 Pusher.
drbelleville is offline   Reply With Quote
Old 12-06-2011, 06:14 AM   #448
Send a message via ICQ to ses414
Hi guys, my RC10L2 has been sitting there awaiting new shaft, meanwhile i saw a corally c10x going at attractive price, shoud i get it?? how is the online part support of corally?? is there commonality between AE parts and corally parts like axle,bearing? thanks!
ses414 is offline   Reply With Quote
Old 12-06-2011, 10:08 AM   #449
Default IRS Axle kit
Is it the IRS2135BL?
Old 12-06-2011, 10:23 AM   #450
Pro10noob's Avatar
That is the one i also ordered for my 235MM Asso project.
regards Roy
l===/o\===l
