Like Tree261Likes
Old 08-11-2017, 02:48 AM   #4306
pphaneuf's Avatar
Originally Posted by howardcano View Post
Was that on carpet? If so, it's an excellent achievement given the narrow body!
An achievement? The narrow Pro10 is pretty much the fastest thing on my local club's carpet! 12th scale might have an even better chance, but the surface is slightly bumpy, and the bigger pan car deals with it better. The fact that I don't have a huge lead is only because I'm such a terrible driver!
TCs with rubber tires have no chance, no matter what kind of motor they have.
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is offline   Reply With Quote
Old 08-11-2017, 07:56 PM   #4307
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Anyone know which chassis' the WRC Pro1/2/3 bodies are intended for? WGT, Speedpassion, Pro-10???
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 08-11-2017, 08:20 PM   #4308
TOADYY's Avatar
Send a message via AIM to TOADYY
Neither, those are an LM body type which is different class and those bodies only fit 200mm cars (WGT chassis). Some tracks might allow you run that body with the WGT-R but you would have to ask. I don't think IIC will allow that body.
PRO 10 is a 235mm chassis and use a GTP type body. i.e. Protoform Swift 235, Peugeot 905b and etc.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 08-12-2017, 03:40 AM   #4309
They also fit F1 cars. I bought one for my Xray and it fit pretty well but didn't perform any better than the stock body/wings in my opinion. It's a very thick lexan and is probably a little too heavy for racing.
edfmaniac is offline   Reply With Quote
Old 08-12-2017, 10:22 AM   #4310
Interesting, thanks guys (or gals?)!
Old 08-12-2017, 05:41 PM   #4311
Johnn27's Avatar
Trader Rating: 69 (100%+)
Default Front Axles!???????????
I have finally tracked down all the parts and a roller to build a RC10L2.5
Should I change to inline axles or keep the front offset that came stock on the car. I am setting up the car to run on large high grip carpet tracks , advanced thanks for your opinion.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-img_4178.jpg
Johnn27 is offline   Reply With Quote
Old 08-12-2017, 07:40 PM   #4312
TOADYY's Avatar
In-line axles will give you more steering and a little more stability. Typical on high grip carpet you will need to take away some steering. If you will be running on asphalt then yes use in-line axles. You can always try the in-line axles on carpet and see if it works for you.
Old 08-13-2017, 12:36 PM   #4313
pphaneuf's Avatar
As edfmaniac mentioned, they're designed for 190mm F1 chassis, with rubber tires. They wouldn't really work well on a 200mm pan car, I'd suspect (a touch too narrow, and the wheel wells would be too big for foam tires).
They're somewhat popular in Italy, and while they don't perform better, they're not too much worse, and they make for more confidently close racing, due to closed wheels vs open wheels.
"Thanks folks/people/everyone" would work in either case!
Old 08-13-2017, 01:45 PM   #4314
ImacFanatic's Avatar
Does anyone have a linkee to decal packs for the 235mm shells ? looking to do a scaleish body , using a P905b , thanks.
This one would be first choice.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-kremer_porsche_962_ck6-007.jpg   Pro 10: 235mm Le Mans Prototype Pan Car Discussion-kremer_porsche_962_ck6-039.jpg
ImacFanatic is offline   Reply With Quote
Old 08-13-2017, 02:31 PM   #4315
Airwave's Avatar
Take a look on The-Border.com
ImacFanatic likes this.
Airwave is offline   Reply With Quote
Old 08-13-2017, 06:21 PM   #4316
So to be clear, they're 190mm with large wheel wells for rubber tire? The first responder said they were 200mm WGT shells.
Old 08-13-2017, 08:58 PM   #4317
Just measured mine. 190mm inside to inside at rear wheel well. Perfect fit for F1 chassis and rubber. The black rimmed P-One tires look sweet under these shells too. But honestly, I think the bodies would be much more well suited for the chassis they were designed to be mounted on. You need to make some mighty crazy looking body mounts to get this thing attached to an F1 properly.
Old 08-13-2017, 09:04 PM   #4318
1/8 IC Fan's Avatar
Trader Rating: 43 (100%+)
Why not use a 962 body to do a scale clone of a 962? Which also happens to be a favored body in Pro10.
MIX Porsche 962 1/10th 235mm Pro10 Body
pphaneuf likes this.
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 08-14-2017, 03:32 AM   #4319
pphaneuf's Avatar
The WRC bodies are designed for their LM16 chassis, which is based off of their F-One chassis. They say that they sell adapters to mount their Pro1/Pro2/Pro3 bodies on other F1 chassis.
If I'm not mistaken, you need their part numbers 03272 (front bumper adapter), 03268 (front bumper), and 02038 (front body posts). I think at the rear, you can use normal body posts?
Old 08-14-2017, 03:34 AM   #4320
pphaneuf's Avatar
More details here, seems like the parts depend on which F1 car you have:
https://www.the-border.com/WRC-1-10-...02024-5-1.html
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rmont3
