Like Tree324Likes
Old 11-09-2011, 06:07 AM   #406
2wdrive's Avatar
Originally Posted by M.Abramowicz View Post
On flat surface will stay, I drive this option with tc5 long time when pack was moved far from center line and bulbs was up
Ah ok. personaly i would want to have something in the slots but good to know it will stay on the chassis with tape only as shown in the video..
I use the slots for two things.
1. to secure the lipo on the chassis so it doesn't move forwards
2. to get the weight as low as possible. I use stripes of construction lead under the lipo's that fall into the slots. Getting extra weight any lower then that is almost impossible. It keeps the rest of the chassis pretty clean as well without the dead weight on top.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 11-18-2011, 12:30 PM   #407
nrtv20's Avatar
I have an old 10L2 chassis laying around that I want to pull back out. Has anyone tried to run with a stick pack on a T-bar car? I just donít want to buy a saddle pack just to see if I like it or can find a place to run it.
Thanks in advance!
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 11-18-2011, 06:53 PM   #408
tallyrc's Avatar
lots of folks run that configuration just fine... me included.. the car balances just fine battery on one side and electronics on the other.. you may need to ballast it a bit but it's easy..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 11-20-2011, 10:16 AM   #409
nrtv20's Avatar
Thanks, I'll try it!
Old 11-20-2011, 11:55 AM   #410
nrtv20's Avatar
WTB used 1/10 235mm Pan car body
Looking to buy some used bodies for a 235mm 10L2.
I dont care if it was for another car, i can put new holes in the body. Just dont want something completely beat up, just need something for a parking lot.
Old 11-21-2011, 03:34 AM   #411
MrChodes's Avatar
As this forum has a bit of life, I'll ask here:
Assembling Serpent S100. Confused about diff balls - Manual shows 8 balls inserted (but not which holes)
My spur has 2 rows of 8 holes (sames as the spur in the manual)
Neither row of holes seem to line up well with the diff ring - both on the edges.
Which holes to use?
Serpent S100. Ducati FM1-e bike.
MrChodes is offline   Reply With Quote
Old 11-21-2011, 03:42 AM   #412
barts71m's Avatar
Trader Rating: 34 (100%+)
Outer holes are usually the go. Only way to fly on my car.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 11-21-2011, 03:50 AM   #413
MrChodes's Avatar
Cheers mate.
I have assembled in outer holes. Looks a bit better once together.
Old 11-21-2011, 03:59 AM   #414
Agree with.....barts......outer holes is what everyone uses.
all4fun is offline   Reply With Quote
Old 11-21-2011, 04:50 AM   #415
MrChodes's Avatar
A bit surprising I can actually see the balls:
Now I know what those covers are for....
Old 11-21-2011, 05:46 AM   #416
Pro10noob's Avatar
Covers?
What covers?
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-21-2011, 05:54 AM   #417
MrChodes's Avatar
Originally Posted by Pro10noob View Post
Covers?
What covers?
regards Roy
Somebody had some white rings - plastic or delrin?
Pretty sure they are a cover to stop or limit dirt getting into the diff.
Old 11-21-2011, 06:07 AM   #418
Pro10noob's Avatar
Aha those.
Yeah got them for my 416 balldiff.
Wonder if they will fit the pancar diffs.
regards Roy
l===/o\===l
Old 11-22-2011, 12:16 AM   #419
2wdrive's Avatar
i tried the kimbrough diff covers some time ago for my kimbrough spurs but they don't work, at least not in outdoor application. Dirt is comming in and can't get out anymore. I haven't used them in a long time.
www.rc-lemans.de
Old 11-22-2011, 03:21 AM   #420
And I 2nd that, diff gets bad faster when using the diff covers..
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
