Like Tree213Likes
Old 03-10-2017, 01:49 PM   #4141
LOW ET's Avatar
Trader Rating: 95 (100%+)
picked up a roche 235mm, any ideas for center/side shock fluids, center/side shock springs, front springs? this will be for mod on asphalt. thanks for any info.
also, when using the mix lola body. i see some have a gurney strip. are you guys just making them or can you buy one ready to go? do you guys use body stiffeners like 1/8 onroads?
Taz_S likes this.
LOW ET is offline   Reply With Quote
Old 03-10-2017, 03:51 PM   #4142
Trader Rating: 22 (100%+)
In other news,
Dear Customers, after a long waiting time, we will start the selling of our new VTE Kits from Monday 20th of March.
All pre-orders get their Infos within the next week!
Look at our blog. Infos an Manual are online!
VIP PERFORMANCE » VTE
Aaaaaand: Our VPL V2 Body will be also in stock next week!
VTE
From Champions for Champions!
VTE Extended Kit
Article Number: VIP-K004
NEW V-Link Geometry – 4mm lower
NEW Sidelink Geometry – 2mm lower
NEW upper damping plate
NEW thinner Chassis with side rails
NEW side Wings
NEW Topdeck for less tweak
NEW Floating Servo holder
Overall lighter…stiffness…more cornerspeed…more traction at low grip conditions.
The wider Pod Kit and HD bumper is including now!
To build a complete car, you need following parts:
7mm rear Axle / IRS Axle with long right Wheelhub and short left Wheelhub (please tell us at order if you want 7mm or 1/4″ Axle)
complete Frontend like: Asso, CRC, IRS, Corally, Xenon, VBC…
small parts like: shocks (central), Sideshocks or Tubes, Springs, Bodyholder and Servoholder
RoyU likes this.
noproblems209 is offline   Reply With Quote
Old 03-20-2017, 03:53 PM   #4143
Still Bill's Avatar
Great thread.
liljohn1064 likes this.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 03-20-2017, 10:34 PM   #4144
JBSpeed's Avatar
Default Expected Run Time for Pan Car on Asphalt
Gents,
I'm just building up a 200mm Pan Car (Racing Classic Group C in Singapore), but just wondering what kind of run time can I expect? I'm rather new to Electric LiPo world (Historically been 1/8th GP Nitro, but have had a 20 years break until last year!). I know that it's dependent on a number of things, but rough order of magnitude would be appreciated. Spec is:
-6.5T Motor (REDS), REDS ESC, 2S Shorty 5000mAh Pack, Car is a Serpent S100.
-Track is outdoor and 1/8th sized, Asphalt, Ambients are 30DegC average.
Run time is my focus, looking for circa 15min (want to practice extended run time).
Thanks in advance, and looking forward to the build, first electric car in 20 years :-)
Kindest Regards,
JBSpeed
Team Atalon.The biggest little racing team in the world.
"If everything seems under control, you're just not going fast enough."
JBSpeed is offline   Reply With Quote
Old 03-20-2017, 11:45 PM   #4145
Moderator
Pro ten Holland's Avatar
The answer is "it depends".☺
Run time depends mainly on rollout and throttle input.
If you're on a large track with high traction level you will be able to empty the battery in 5 minutes, particularly if you run a rollout that is set to wring the last bit of speed from the car.
If you want to set up your car for long runtime, start with a conservative rollout and start with some shorter runs to figure out your battery consumption. Running blinky and minimal motor timing will also help.
Always be careful with long runs on lipo batteries. Don't go below 10% of the battery capacity or they'll get damaged.
Pro ten Holland is offline   Reply With Quote
Old 03-25-2017, 12:34 AM   #4146
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Which front end works well for pro10?
Thinking about picking up the VIP VTE so I need a front end set.
jetnjme likes this.
lagcisco is offline   Reply With Quote
Old 03-25-2017, 01:54 AM   #4147
Pro10noob's Avatar
Associated R5 style as almost every one uses in some sort of variation.
Even Tobias from VIP uses the lower part of it
Regards Roy
jetnjme and pphaneuf like this.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-29-2017, 02:51 PM   #4148
The second round of the Catalonia Pro10 Championship was held at the Rubí track this past weekend. In the Modified class Marc Valero took the overall TQ and he would also walk away with the day’s win after some very close A-mains. Jaime Lacuesta would take the runner-up spot at round two with Sergio Lacuesta coming in 3rd.
1- Marc Valero
2- Jaime Lacuesta
3- Sergio Lacuesta
Source: http://pro10.cat (Pictures, videos...)
Taz_S, liljohn1064 and pphaneuf like this.
TyoBBS is offline   Reply With Quote
Old 03-30-2017, 01:18 PM   #4149
Airwave's Avatar
What kind of Lipos are you running?
Standard? Saddle? Square? Shorty? Double 1s shorty? What configuration has your preference? and why?
Airwave is offline   Reply With Quote
Old 03-30-2017, 01:58 PM   #4150
YoDog's Avatar
Trader Rating: 26 (100%+)
I started out with dual 1s in my BMI but now prefer the lighter weight of the shorty pack. It's installed transverse all the way back. I have had a couple of blow overs so I might want to try a square pack sometime or move the shorty more forward.
YoDog is offline   Reply With Quote
Old 03-30-2017, 08:21 PM   #4151
Brand new Speedmerchant Roadkill Pro10 ready to go.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-img_0301.jpg
Taz_S, TOADYY, THEBIGBULL and 4 others like this.
team_tamale is offline   Reply With Quote
Old 03-30-2017, 08:30 PM   #4152
Johnn27's Avatar
Trader Rating: 68 (100%+)
Thumbs up front end
I run an associated and the speed merchant was recommended to me .
Speed Merchant sells the front end as a kit.
Johnn27 is offline   Reply With Quote
Old 03-30-2017, 09:39 PM   #4153
Exclamation
Best 10pan I ever had. I have one of the first 10 sold !!!!!
THEBIGBULL is offline   Reply With Quote
Old 03-30-2017, 09:40 PM   #4154
Pro10noob's Avatar
Running 2x 1S batteries on the JKMR P235 SE and brink lipo's on the V-link Proto type.
The V-link can also be easily converted to shorty by exchanging the topdeck and battery holders.
Why?
Better weight distribution on the SE with the 2x 1S and the V-link proto type is also my rain car so when converted to shorty you got perfect room to put a water tight receiver box just behind the steering servo.
Regards Roy
l===/o\===l
Old 03-30-2017, 09:53 PM   #4155
TOADYY's Avatar
Send a message via AIM to TOADYY
Nice! Looks like you cut a new chassis and have the Fenix dif. Let us know how you like that diff.
pphaneuf likes this.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
