Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#271
Virtually all pancars, 12th and 10th scale use the 1/8" diff balls. Go with the Kimbrough spurs, they will last and indeed make sure that the bearings are in good condition as well as the space between the pinion and spur...
Also check the locknut on the diff on regular bases and replace when needed...
#272
What rollout would you guys recommend on a medium-large track with medium-high grip, 10.5t 2s?
#273
That depends on which motor and ESC you are using.
But without that info I would say somewehere around 40 - 45mm. roll-out. Then check the motor temp every 2 minutes and go up or down from there. Also try to listen to the motor when you are accelerating on the straight. If the motor is at its top RPM within a some meters then go to a higher roll-out. If it keeps on revving up until the end, go a to a lower roll-out.
#274
Im running Tekin RSpro and tekin10.5 motor.
#275
If you know how to set up a tekin rollout should be around 36-40mm.
#276
MIX bodies reproduced the 235mm Hotbodies Nissan. Yet another body to add to the list.
#278
The RC10L2 doesn't work with the D-rings in the diff yet and also still has a left hub with a set screw. This type of axle is near vintage and actually it is not really a bad thing that you have broken it because now you can replace it with a good type axle that works with the newer D-drive diff rings and has a clamping left hub...
The answer??? IRS...
Go for the complete axle set from IRS including al the hubs and hardware, it will please you and your car...
#IRS2135 1/10th Graphite Pro Axle Kit
#IRS2135BL 1/10th Graphite Pro Axle kit - Blue
#279
You can find it here:
http://teamirsrc.com/index.php?main_...4alh29sv1rmo62
or here:
https://www.ssl-stormerhobbies.com/c...=ns&pn=IRS2101
or here:
#280
not sure in what part of the world you are but there is an online shop in germany that sells IRS axles and hubs http://www.rc-bodies.de/shop/index.php?cPath=53_54
#282
#283
itīs this car http://www.moosi-masters.com/downloa...4469&mode=view
#285
