Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#2311
If you raise all 5 balls you take away grip from the rear end.
You can raise the 2 front balls only. You will get a slight corner steering of the rear axle, as the curve outside link will elongate slightly and the inner side link will shorten slightly while deflecting.
#2312
That's interesting, as he's using a V-link connection, so the roll center is in the ground...
#2313
So, with a V-link connection, if I raise the side-links, I'll raise the roll center; which means I'll get less rear grip, correct?
I'm a bit confused with pan car roll-center...
Thanks,
G-rem
#2314
The height of the side links will change the amount of anti-squat: higher gives more.
#2315
Thank you Howard, exactly the explanations I was looking for
#2316
If anyone has any questions about these tires, feel free to ask the people that actually know what is going on. You can PM me, call CRC (315)-338-0867 or email me [email protected].
Brian Wynn
Team CRC
#2317
#2320
I'm not sure where these rumors come from, as no one has asked myself or anyone else that works at CRC, but to put the truth out there, these tires ARE BELTED.
Brian Wynn
Team CRC
Brian Wynn
Team CRC
Do you have any recommendations for maximum allowable RPM at the wheel?
Are they in stock? EDIT: Due 9/1/15
#2323
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
What kind of performance would rubber tires have compared to foams on asphalt?
#2324
The more realistic appearance and (hopefully) longer life of rubber tires will be welcome changes.
#2325
