Like Tree85Likes
Old 01-23-2015, 09:51 AM   #1876
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by TyoBBS View Post
Thank you for all answers
Exist any WGT body for 235 chasis?
REGARDS
Not on the approved body list. WGT is considered a 200mm max width class. All the 235mm bodies I've found are LMP type.
John Higgins
liljohn1064 is online now   Reply With Quote
Old 02-01-2015, 01:13 PM   #1877
joezjr's Avatar
I know this isn't a fs thread but I would like a used sm roadkill 10. Just trying to avoid buying new. I'm cheap. Lol
MNRC committee member
Talking head on Ran Out of Talent podcast
joezjr is offline   Reply With Quote
Old 02-02-2015, 12:30 AM   #1878
Originally Posted by patorz31 View Post
Anyone pick up a VBC Lightning 10 235mm kit yet?
Yep
Gero is offline   Reply With Quote
Old 02-02-2015, 12:15 PM   #1879
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
Originally Posted by Gero View Post
Yep
how do you like it?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-03-2015, 07:23 AM   #1880
Is it possible to use other than shorty batts for the VBC? ANd how does it look like with the weight distribution in the rear pod? The motor is quite far on the "heavy" side.
puttekula is offline   Reply With Quote
Old 02-03-2015, 07:27 AM   #1881
Trader Rating: 26 (100%+)
A little birdy has told me we will be having a 235mm 1s GTP mod class at the IIC this year.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 02-03-2015, 09:37 AM   #1882
hanulec's Avatar
Trader Rating: 23 (100%+)
Oh hell yes!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-03-2015, 10:10 AM   #1883
TOADYY's Avatar
Send a message via AIM to TOADYY
I'm in!!! Oh, boy this is going to be fun! HEHEHE
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 02-03-2015, 10:12 AM   #1884
Originally Posted by RAL View Post
how do you like it?
Build is smooth and the carbon Quality is awesome.
Just two strange things with my kit:
1st the metal kingpin Pivots are a very tight fit an bind a Little bit.
i jused dry fluid to fix this Problem.
2nd the carbon brace of the pod is milled a Little bit on Position of
the screw holes. It's just approx 1mm, but it's enough so that the screws
are to Long. I put in a shorter screw to fix this Problem.
You could also use a shim.
Haven't drove it, but yes, you could put a normal sized 2s lipo in.
Just build it to see what i can do "better". I will use mkost of the parts
and build an own Version.
Old 02-03-2015, 11:06 AM   #1885
Oh, oh, oh I would like to see that Let's bring back the 235's and get mfgs to produce the old and newer GTP/Grp C bodies
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 02-03-2015, 03:25 PM   #1886
Oh my. Way cool!
John Higgins
Old 02-03-2015, 09:28 PM   #1887
Ok, and how about the weight distribution in the rear pod. Isnt the motor far away on the right side?
Do you have to mount the esc on its side when using normal 2s?
Hmmm ,Emden? Is there any good track around there? I have been there a couple of times.
Old 02-04-2015, 06:10 AM   #1888
jetnjme's Avatar
this would be cool.
Northern California Pan Car Revival
jetnjme is offline   Reply With Quote
Old 02-04-2015, 06:38 AM   #1889
If we as a collective group of clowns who have fascinations with these awesome cars want them to make a comeback, a couple of things have to happen. First, the cars have to be viable for a track/big race promoter to welcome them. 2S in any form just isnt going to work. They have ran World GT mod at IIC and it has worked. 1S mod will be the same speeds as 12th scale mod but with way more grip and stability. As far as tires go, what do you guys think of utilizing WGT spec tires as well?
Steve Boice
Old 02-04-2015, 12:47 PM   #1890
We've run the Lilacs with 2S 10.5 on carpet and they are fine on our Roadkill 10s. That chassis has proven that it's still stable with pretty much any motor or tire combo you put on it. I've just converted to 17.5 boosted 2S to try it. Still working out the bugs, but it ran laps 2 full seconds faster than anything else at the track last night. Maybe I should put the 10.5 back in and convert to 1S next? I don't see any downside for 1S indoor.
John Higgins
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
