Pro 10: 235mm Le Mans Prototype Pan Car Discussion
#1846
This is from another post, good to see 235mm cars making a come back!
http://www.rctech.net/forum/electric...m-pan-car.html
#1847
Other than the Protoform 235 bodies...who's using what for a Pro10 - 235mm class (and on what surface type)?
I have the old ANDY's TOJ bodies, but I've only got one NIP one left..and looking for options that will give similar handling.
I know STORMER HOBBIES came out w/ some new bodies a couple years ago - the Osella and the TOJ sc306, I thought they had a 3rd one, but I haven't found it again.
(He had some of the ANDY's bodies too - but I doubt he'll let loose of those)
#1849
Note to Dale!
Something with more down force for people who want to use less weight in the car or running 1s packs(US)would be nice. Also a way to incorporate the appendage type lip on the front of the Peugeot body into the design of the front end while keeping the steering it provides would be nice.
#1850
Hello guys. Need some advise on side shock, spring. I am trying to convert my normal "small side spring" link car to 3 shocks setup. With 3 trf shocks. Would would be a good starting point running 2s 4.5T outdoor? For side spring and center spring, and oil / piston? Thank you in advance!
#1851
I wouldn't take the bigger TRF shocks as side shocks. Simply because they are too big.
Better take two Silva shocks or two CRC encore shocks.
You have a wider range in springs.
Which spring and oil you should use depends on the track, the grip etc.
#1853
Start reading the thread man... We all had to...
The only thing that happens without any effort is sunrise... Have fun...
#1854
I run Xceed carpet medium front and rear with the Protoform HD P905b body. My car doesn't lift in the corners. BSR purple fronts and Pink or Pearl White rears rears work great also.
#1858
Thank you for your advise! Really hard to get the CRC shocks in HK...... I will be running 4.5 boosted at an outdoor nitro track. Around 100m straight. So It will be a large track.
