Like Tree38Likes
Old 09-01-2014, 02:45 PM   #1726
Joost K.'s Avatar
Thanx for the props...
I have to admit, the topplate does flex just a little bit but only if you put real force on it. Overall, with the new thick lower, the rearpod is really strong and rigid.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Orion | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 09-01-2014, 03:42 PM   #1727
OrganicMechanic's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Pro10noob View Post
The top plate won't flex.
With the alloy lower podplate, it won't flex at all
With the new design lower carbon pod plate the car is even more stable then before.
It is now from 3MM carbon.
Regards Roy
3mm carbon lower, nice. What is the thickness of the top plate?
GT12- Schumacher Supastox GT
MARCCA Member
OrganicMechanic is offline   Reply With Quote
Old 09-01-2014, 03:50 PM   #1728
Pro10noob's Avatar
I believe it is 2.5MM.
Have to check to be sure.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 09-01-2014, 05:39 PM   #1729
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Ehmm... THAT doesn't work with IRS podplates. The only podplate that you can use to do what you say is the CRC #3340 podplate. IRS podplates do not accept ride height adjusters on both sides. It may fit but it won't flush into the motorplate as is does on the diff side.
If you do so, the left podplate will have the ride height adjuster on the inside and that will not work.
Take a look at my P235-SE. That is also a good solution on how to make an upper podplate...
Correct. I'm from the CRC world. Your solution is more like what I was thinking.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 09-01-2014, 11:47 PM   #1730
Roller
Complete, with stock lower plate and handmade upper plate. Ready to test. Still have not been able to hook up with my machinist to get the lowers made... patience...
Pic of motor wires clearance and routing. The current layout doesn't cause any binding or tweak whatsoever even with 12ga motor wires. Best angle I could get...
Hopefully get the body painted tomorrow and get it to the track!
MARCCA Member
Old 09-01-2014, 11:51 PM   #1731
Pro10noob's Avatar
Sweet
Regards Roy
l===/o\===l
Old 09-02-2014, 03:33 PM   #1732
fathead's Avatar
Got the rear end mostly on my test car now
Slavich Design
fathead is offline   Reply With Quote
Old 09-03-2014, 04:27 AM   #1733
tudor_47's Avatar
double post
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 09-03-2014, 04:38 AM   #1734
tudor_47's Avatar
Coool , like stranaham 3-link rear end, I've been wanting to test that my self but never gotten around to it.
Keep us posted on your progress!
What dampers are you going to use?
Old 09-03-2014, 02:37 PM   #1735
fathead's Avatar
Yes I definitely took inspiration from Johns car!
Should be first test of the whole chassis this weekend after testing the front end only previously
Currently for this test hack I am running RC18 shocks front and rear, these will be changed later to something else.
Slavich Design
Old 09-03-2014, 05:03 PM   #1736
Originally Posted by OrganicMechanic View Post
Roller
This car looked plenty fast last night. Soon, very soon we will be racing them.
John Higgins
Old 09-03-2014, 05:47 PM   #1737
OrganicMechanic;
I've got a slightly off-topic question for you. What brand wheels are on this car? (in the photo) Where did you get them?
Thanks - Dale
Pro 10: 235mm Le Mans Prototype Pan Car Discussion-what-wheels-.jpg
PROTOform Race Bodies
www.racePF.com // www.facebook.com/PROTOformRaceBodies // www.twitter.com/RacePF
daleepp is offline   Reply With Quote
Old 09-03-2014, 06:35 PM   #1738
Originally Posted by daleepp View Post
OrganicMechanic;
Thanks - Dale
I wish I could take credit for that piece of art in the pic, but the credit goes to Joost K. as it is his prototype car.
To answer your question, the wheels are Xceed brand foams. Amain.com carries them, along with other places.
Thanks for continuing to produce the P905B body! Any chance you have another 235mm body in the works? I have a Protoform Nissan P35 NIP that I wouldn't mind seeing reproduced.
MARCCA Member
Old 09-03-2014, 06:57 PM   #1739
TOADYY's Avatar
Send a message via AIM to TOADYY
Dale, any chance you can produce the medium down force 905? The high down force produces to much down force for most tracks
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 09-04-2014, 01:33 AM   #1740
Thumbs up
++++++++++++++++ Please, please,please.
THEBIGBULL is offline   Reply With Quote
