Like Tree262Likes
Old 08-27-2014, 02:43 PM   #1711
Pro10noob's Avatar
The front end of the 235 kit is ok but the rear extension hubs can cause vibration after some time.
Better try the LAJF kit---> http://lajf.se/pshop/index.php?id_ca...gory&id_lang=1 with a IRS axle
Speed merchant is also a option.
Regards Roy
Originally Posted by lagcisco View Post
Really considering a Pro10.
What do you guys think of the Speedmerchant Roadkill 10 vs CRC GenX 10SE with 235mm conversion kit?
I already have a CRC Carpet knife I'm happy with.. so I'm just a bit partial to CRC but am open to other options.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-27-2014, 04:10 PM   #1712
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Default Rollout with 1s?
My CRC LE is set up at 235mm, using a Peugeot 905 B HD body and BSR capped tires. RR tire is 2.45" diam. Electronics are a sensored 17.5 turn brushless motor, a 1 cell battery and a Turnigy 1 cell ESC. Radios are Spectrum. The track is an outdoor concrete basketball court. I need suggestions on how to gear this car and/or what the roll out should be. Thanks for your help as I've never tried a single cell in a pan car before.
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Cancun Tom is offline   Reply With Quote
Old 08-27-2014, 05:45 PM   #1713
celt's Avatar
The RK10 is the most stunning chassis I've ever wheeled.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-27-2014, 11:01 PM   #1714
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Try high 80s. That's where I start with my WGT.
I have to ask, why 1S? Im running 2S 10.5 boosted and its drivable. It takes serious throttle control on a 100 foot straight, but that is the point. I'd skip right to 17.5 boosted with that setup or you will get bored silly.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-27-2014, 11:12 PM   #1715
I have 2 LEs and CRC 12th. After driving a purpose built 235 pan car, the Roadkill 10 by SpeedMerchant, I will not hesitate to buy another of their products. The geometry is completely different with much wider links than any conversion, no addon parts or additional axle set to buy which leads to a solid feeling drive every time I set it down. So far celt and I have logged several hours on our cars an not one failure or broken part. I would buy another RK10 before I'd buy a conversion.
Old 08-29-2014, 01:29 PM   #1716
Cancun Tom's Avatar
Default 1s Rollout
Lil John,
So i assume that you mean a rollout between 85 & 89mm?
The only reason I can give is that I wanted to try a 1s setup, I guess from back in the day when I ran 4cell NiCd 12th scale. So it's an experiment.
Old 08-30-2014, 12:02 AM   #1717
Lil John,
Yes, sorry, that is in mm.
I understand. I still have a 17.5 blinky 12th and actually ran it this week. The 235mm wide car can take a lot more motor. Once you get done with your test, try it with 2S.
Old 08-31-2014, 08:11 PM   #1718
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
Default rough draft upper pod plate
Finally made some headway on the 10L2. I hand made a couple rough drafts of the upper pod plate, still needs a few changes. The pics are of my 2nd draft, I'm going to apply the changes to the 3rd and final draft before the nice CNC copies are produced. Also hopefully getting the aluminum lower plates made tomorrow, hard to find the time...
OrganicMechanic is offline   Reply With Quote
Old 09-01-2014, 01:50 AM   #1719
Pro10noob's Avatar
Nice one OrganicMechanic, make sure that the middle and left spoke of the top plate don't get in the way with the soldering tabs of the motor.
Also make sure that you have enough room to place the motor without having to remove the top plate.
Or do you place the motor from the lower side?
Regards Roy
l===/o\===l
Old 09-01-2014, 06:38 AM   #1720
Regards Roy
Thanks! I was going to try an open upper plate design similar to the PRC, for ease of solder tab access. I decided I would rather the plate have proper leverage and rigidity. The motor easily slides in or out through the lower pod plate anyway, and with the solder tabs facing forward everything fits just right. So to swap motors all I have to do is drop the motor out the bottom side, unsolder/solder motor wires, the slip the new motor back in and done. I don't plan to swap motors often but even when I do it will be easy enough.
Old 09-01-2014, 10:03 AM   #1721
Simple, Use motor mounts on both sides, then you don't need the triangle all the way to the back of the pod on the left side. The motor mount is universal and machined to accept the ride height adjuster from either side. Try it if you don't believe me. Now the top brace triangle can stop at the front of the pod and connect to the front or both motor plate top holes on the left side. Looks like you'll have to keep the brace across the back though. No place to mount one elsewhere on the back of the plates.
Old 09-01-2014, 10:34 AM   #1722
Joost K.'s Avatar
Ehmm... THAT doesn't work with IRS podplates. The only podplate that you can use to do what you say is the CRC #3340 podplate. IRS podplates do not accept ride height adjusters on both sides. It may fit but it won't flush into the motorplate as is does on the diff side.
If you do so, the left podplate will have the ride height adjuster on the inside and that will not work.
Take a look at my P235-SE. That is also a good solution on how to make an upper podplate...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 09-01-2014, 11:29 AM   #1723
Pro10noob's Avatar
Here you go
Regards Roy
l===/o\===l
Old 09-01-2014, 11:47 AM   #1724
Thanks for the idea. The bad news is that will not work with the Associated plate or the IRS plate. You can see in the 3rd pic I posted what the IRS motor plate looks like. Good idea though if it had worked out.
Beautiful work on the P235-SE, especially the stealth look. So I assume I'm wrong to think your plate design or the PRC plate design has more flex then the design I went with? Maybe my third draft will look closer to the PRC and P235-SE upper plates if that's the case. I at least have the side shock mount points worked out lol.
Old 09-01-2014, 12:53 PM   #1725
Pro10noob's Avatar
The top plate won't flex.
With the alloy lower podplate, it won't flex at all
With the new design lower carbon pod plate the car is even more stable then before.
It is now from 3MM carbon.
Regards Roy
l===/o\===l
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
john holmes 69
