Like Tree213Likes
Old 08-23-2014, 11:22 AM   #1666
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
Originally Posted by liljohn1064 View Post
Sure I could change the gearing, but I'm temping at 120 or less for 8 minutes. And for this short of a straight, Turbo isn't necessary. I'm not even using all of the boost. Our track is big with a 100 foot straight, but not enough for Turbo to be of use. When it comes to boosted with turbo, I have it pretty much nailed down. Years ago, my 17.5 sedan was the first locally to have it figured out and I could rip past the 13.5 super stock (preblinky) easily. The difference between a boosted and blinky setup for 48P is roughly 3 teeth off the pinion, maybe 4 about 1 to 1.5 FDR points. If I don't hit WOT, It doesn't bother me. It just means I have more motor than the track can handle. The car itself could handle gobs more motor. I'm still in lovin' it.
Turbo function comes on after boost, after .1 sec WOT and takes about 1.5 seconds to max out based on ramp rate. I may hit WOT, but I need to stay @ WOT to run it all the way up. By that time, my car would be 100' past the sweeper and still accelerating (and pulling like a freight train.)
Cool, just thought I'd throw it out there.
Wow your Tekin ESC is quite different then my Hobbywing ESC. MY HW 120A ESC allows the turbo to be activated by RPM, WOT, or both. The turbo engage/disengage slopes can even be instant.
OrganicMechanic is offline   Reply With Quote
Old 08-23-2014, 11:31 AM   #1667
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Yeah, I have a few Tekin RSs. I'm sick they aren't used the right way. I finally have one out it's shackles.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-23-2014, 11:31 AM   #1668
Joost K.'s Avatar
Up until now I had all the milling done by a good friend of mine.
Anytime soon I will start the build of my CNC router.
After that all the parts will be made in home. There is also a good chance that a lathe is joining the tool party anytime soon.
Then I can concentrate on the design of the new chassis...
Thanx for all the compliments though, always nice to hear...
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 08-23-2014, 11:35 AM   #1669
Your welcome keep up the good work! and as always post pics! Especially of the CNC your building, very cool.
Old 08-23-2014, 11:37 AM   #1670
Joost K.'s Avatar
Thank you... Offcoarse we will continue posting on whatever we are doing.
Old 08-23-2014, 05:33 PM   #1671
fathead's Avatar
My friends Xray ready for a run/test
Slavich Design
fathead is offline   Reply With Quote
Old 08-23-2014, 05:58 PM   #1672
What front end is on there?
Old 08-23-2014, 06:06 PM   #1673
fathead's Avatar
My own front end, it's a prototype test hack currently, double A-arm, it's a combo of parts I had laying around mostly from various different cars plus a couple cnc'd bits.
Almost finished the 3 link rear to test with it now too.
Slavich Design
Old 08-23-2014, 06:35 PM   #1674
Very cool!
Old 08-23-2014, 10:38 PM   #1675
TOADYY's Avatar
Send a message via AIM to TOADYY
Finished and ran my RK10 today. Here are the links
Speedmerchant Roadkill 10 235mm Pro10 Pancar
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 08-24-2014, 12:31 AM   #1676
Pro10noob's Avatar
Nice looking car Toadyy
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-24-2014, 06:05 AM   #1677
celt's Avatar
What's the rear track width on the XRay?
Looks long and narrow, maybe it's just the image.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-24-2014, 07:31 AM   #1678
Joost K.'s Avatar
200mm. out of the box. The X-ray is a WGT chassis...
Old 08-24-2014, 12:35 PM   #1679
fathead's Avatar
Yes 200mm currently, but will be converting to 235mm soon, we run 200 & 235 together, both with 13.5 2S
Old 08-24-2014, 12:37 PM   #1680
Pro10noob's Avatar
LAJF has a nice kit for the Xray so you can use a IRS rearaxle.
Works like a charm
Regards Roy
l===/o\===l
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
aalewis
