Old 09-05-2009, 08:01 PM   #1
Default What grease where ??
Hi there.
What grease should I use where on my RC cars
or does it not matter...
ceramic, moly, cera/boron, FLUOROPOLYMER, anti wear, axle grease
1101 is offline   Reply With Quote
Old 09-05-2009, 08:52 PM   #2
Danny-b23's Avatar
Diff Grease: In between the diff ring and the diff balls.
Moly: Thrust Bearing
Anti-Wear: On the outdrives if you don't have blades on your driveshafts.
Axle Grease: On the cup that attaches the driveshaft and the drive axle.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 09-05-2009, 08:57 PM   #3
niznai's Avatar
The grease you need usually comes with the kit.
Bearings should be oiled not greased. There's specialised oils sold by hobby shops and I am not cognisant enough to recommend anything else.
About grease, the diffs need two different kinds of grease (those that come in the kit). One is silicone grease (white, waxy), the other is a thicker, stickier grease. The white one goes on the large diff balls, the other one goes on the thrust bearing/balls. Tamiya calls the latter "antiwear" and this is what they recommend on driveshafts as well.
As for silicone grease you can get the industrial grade (I get the Molykote brand, perhaps there are others) and that's way cheaper and will last you a lifetime so you don't have to skimp when rebuilding diffs.
Ceramic grease is used on gears and again comes with the kits. You can get it in larger tubes from hobby shops.
Is this what you wanted to know?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-05-2009, 09:16 PM   #4
vazzo's Avatar
Trader Rating: 100 (100%+)
Diff Grease: Schumacher
Thrust Bearing: Associated Black Grease
Shock O-rings: Green Slime
Diff Rings on outdrives: Tamiya Hard Grease
For anything else KY Jelly
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 09-05-2009, 10:11 PM   #5
xevias's Avatar
I use stealth lube for the diff - black grease for the thrust bearing and that's it.
No grease on the universal joints, bearings, or anything else. Lube just attracts dirt and fuzz and causes more wear problems.
Get metal shielded bearings from Fast Eddies for $1 a piece.
xevias is offline   Reply With Quote
Team Losi XXX-T CR, What are yours opinions ? Jason Pelletier Electric Off-Road 2231 01-19-2012 09:16 PM
What do I need to do to maintain an RC car? sokar Nitro Off-Road 17 07-25-2009 02:18 AM
What to use to lock a truggy center diff? Kimixii Nitro Off-Road 6 07-23-2009 06:29 PM
Mini racing ...... Where is the future? cannon Australian Racing 310 01-30-2009 12:06 PM
Going to build a Losi Diff...what do you recommend? y2kgtp Electric Off-Road 17 11-11-2008 08:37 PM
WHAT IS THE BEST 1/5 SCALE CAR OUT THERE ? Crazy Carl Oval, Larger Scales and More 45 03-26-2008 09:44 AM
SEO by vBSEO 3.5.0
