R/C Tech Live @ the 2004 Trinity/Car Action Snowbird Nationals >
Like Tree1Likes
Old 02-11-2004, 07:14 PM
  #676
R/C Tech Founder
As I posted above, that is coming soon. I didn't have a chance to type the stuff up while I was at the race so I am getting it from XRC.
futureal is offline
Old 02-11-2004, 07:19 PM
  #677
davepull's Avatar
i think that the way to fix the warping problem with the wood would have to be using 2 layers of treated wood that are screwed together and overlapped. also i noticed that the pit road really doesn't get used so get ride of it and extend the onroad course alittle. also last year the road course lay out was different those 2 180's that were on the on road course this year were placed right in the oval grove. that meant that that portion of the track had a shat load of cars on it.
Katfish did you run jack the slipper???
davepull is offline
Old 02-11-2004, 07:24 PM
  #678
KMac's Avatar
Use roofing clips to hold the edges of the sheets together. Very Cheap, Very easy.
KMac is offline
Old 02-11-2004, 07:33 PM
  #679
davepull's Avatar
yah but 2 layers of wood would help out alot
davepull is offline
Old 02-11-2004, 07:37 PM
  #680
RC Scoring Pro's Avatar
Tongue and groove boards or rent a dance floor. Mike will have it fixed, don't worry.
RC Scoring Pro is offline
Old 02-11-2004, 07:45 PM
  #681
Default Warping
ONe way to stop warping would be tp use marine grade plywood. 1/2" would suffice to do the job. Build a false floor under it the lay the marine gade stuff down. Place either 1x2's or 2x4's on the floor, having them spaced appropriately apart, depending on the size area. Then screw the marine gade stuff down, then lay your carpet, with the plywood off the floor even the slightest amount air will be able circulate under it to allow for movement in the plywood,..if there is a gap of approx. of a 1/4" the plywood be able flex and "breath" in conditions like what you guys had in Orlando. This would help eliminate the warping you had.
HMS80 is offline
Old 02-11-2004, 07:57 PM
  #682
Did anyone get any chassis pictures of the Custom Works oval prototype that was there? I understand that it won the main.
Please post them asap.
Team Lotus is offline
Old 02-11-2004, 08:09 PM
  #683
davepull's Avatar
Default question for scoring pro
with the autoscore program you have to wait till the entire round is run to resort. with your program can you resort by class while the qualifying round is still running?
davepull is offline
Old 02-11-2004, 08:12 PM
  #684
CLICK on this!
Cool Race From Snowbirds!
Check out this race. LeMieux had lap times of
10.97 (Fastest lap of the race)
10.98
10.99
11.01
Scotty did a great job to getting second by .003
Andrew Gray had a 16 second last lap.
Old 02-11-2004, 08:23 PM
  #685
R/C Tech Founder
Working on it at this very moment.
futureal is offline
Old 02-11-2004, 08:24 PM
  #686
nashrcracer's Avatar
must go faster!
nashrcracer is offline
Old 02-11-2004, 08:31 PM
  #687
davepull's Avatar
another thing that I didn't care for was the order in which the classes where run. 12th scale on road was always the first class out. after running all the oval stuff the 12th scale cars don't really help lay the groove down. maybe next year the can start with touring stock then 12th stock then the 19ts 12th mod and pro mod last.
davepull is offline
Old 02-11-2004, 08:56 PM
  #688
This is not the first time the boards have came up. They did the same thing in 2002. It could have been 2001. Which ever it was,I was there. I really can't remember. " paragon poision" This is still a heck of a race!
i
speedshop is offline
Old 02-11-2004, 09:08 PM
  #689
tmunno's Avatar
Default concourse winners
TC3er in the first class most authentic. Greg Busch won with a Tony Steward paint job (American Flag/Home Depot car) This car was painted by Lynn Munno. 2nd place went to a Mustang done by Roly. In the best paint class Steve from MDI with first and second with paint by Roly and Lynn took third for her Dragon car. There were some pretty wild paint jobs from alot of painters, but the two Fl. painters (Roly and Lynn) did the best overall.
tmunno is offline
Old 02-11-2004, 09:18 PM
  #690
Default Working harder.....
Racers,,, we are listening. I know there were a few issues this year that will make the race even better for 2005 if we can fix. You can trust us that we will work hard as heck to make the race better for everyone involved. Thanks for the input and enthusiasm.
Mike
RCThunder is offline
