Old 01-29-2004, 02:31 PM   #1
rc_square24's Avatar
Default ways setting tweak
as far as i know, methods of setting tweak are: adding weight, making shocks longer, using the tweak screws/downstops and flattening chassis/resetting top deck screws.
what are the differences between these methods?
rc_square24 is offline   Reply With Quote
Old 01-29-2004, 02:52 PM   #2
psycho's Avatar
Default Re: ways setting tweak
There is basically two ways. One is to fix imperfections in the chassis setup (adjusting shock preload, tweak screws, etc.) and compensating for weight imbalance (adding weight in a particular area.) Generally, if you install your electrics where they're supposed to be installed, you shouldn't have to worry too much about weight imbalance. You may have to slightly compensate for a heavy servo or something like that, but you usually don't want to add weight if you can help it. You're much more likely to use chassis tweak adjustments since it's impossible to eyeball exact preload adjustments or tweak screw adjustments. For that, you will need a tweak station.
MIP, Integy, Niftech and others make them and they range from $40-100.
psycho is offline   Reply With Quote
one-ways stephen hilton Electric On-Road 2 01-27-2007 08:38 AM
$%^%$^ONE WAYS$%^#$% EDWARD2003 Electric On-Road 10 12-12-2005 04:26 AM
Tape -vs- battery brace "To tweak or not to tweak is the question" dawgmeat Electric On-Road 37 11-17-2005 12:05 PM
one way going 2 ways? corvettecrazy Onroad Nitro Engine Zone 2 04-01-2004 02:11 PM
TC3: What are the best ways to.... RoadRat Rookie Zone 0 05-19-2003 02:07 PM
SEO by vBSEO 3.5.0
