Old 09-01-2009, 10:50 AM   #46
Regional Moderator
CarbonJoe's Avatar
Actually, Hakko makes a similar paste, but theirs is $10 for 10 grams, the Radio Shack stuff is $7 for 14 grams. The link you posted was for the metal tip cleaning "sponge", but this paste also re-tins the tip to help prevent oxidation. Big difference.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-01-2009, 11:12 AM   #47
amnesia's Avatar
I use a 25W Antex soldering iron, and 60/40 Hudy solder. The iron has tips that sit OVER the element rather than slot inside. This seems to hold a lot more heat.
Never had any problems... I just make sure I keep the tip clean and tinned. Heat transfer is a LOT easier if you tin the tip.
Not sure I would attempt batteries with a 25W though.
.-= T.O.P. Photon =-.
Titanium Racing (Team TR Driver) / Tekin RS Pro / Novak Ballistic 13.5t / Spektrum
amnesia is offline   Reply With Quote
Soldering irons Cougar R/C Tech Site Forum 11 11-30-2005 03:38 PM
Scope Soldering Irons - where can i find them? Carbon_Fibre3 Australian Racing 13 07-03-2005 02:28 AM
Temp of watts on Soldering Irons scoobydo Electric On-Road 18 04-01-2005 04:51 AM
soldering irons John Q Electric On-Road 41 02-07-2005 01:26 PM
SEO by vBSEO 3.5.0
