12th - 13.5 an lipo 1S - What gearing ?
Hello,
All is in the title - What spurs and pignons, i have to use in a 12R5 with an brushless 13.5 and a Lipo 1S 3.7V ? Thank you |
Really depends on what speedo/motor your running. I have been in the 3.1 - 3.18 inch roll outs with normal speedo. 73 spur 40-45 pinion depending on tire size.
DK |
As said above, depending on tire size! I am running a 74 spur with a 42 pinion and it flies around our track!
Thank you guys for the reply - 40-45 / 73-74 in 64DP or 48DP ?
Thanks ! |
I may be wrong here but I believe all newer cars use 64pitch. Only thing I've found that use 48 is my TC3 for vintage. But I've been wrong before.
