Old 02-21-2002, 08:32 PM   #1
TRF-Powered's Avatar
Default Turnbuckle tie-rods
I have been looking around from some turnbuckle tie rods. However, the size that I'm looking for no body makes them. They are 32mm, 23mm, 15mm, and 52mm.
I just wonder since no one makes the exact size, can I just buy what's close to it??? and if I do buy the size that's close to it, should I buy a bit shorter ones or a bit longer ones???
TRF-Powered is offline   Reply With Quote
Old 02-21-2002, 08:38 PM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
What car is it for? I would buy ones close to the same size. Try converting the metric numers to inches. ##mm/25.4=inches
Example: 32mm/25.4=1.25 inches or about 1 1/4 inch
CRASH is offline   Reply With Quote
Old 02-21-2002, 08:43 PM   #3
Jack Smash's Avatar
Trader Rating: 28 (100%+)
I'd buy a bit longer and grind them down to the right size. If you buy them too long, they could bind the ball cups.
Jack Smash is offline   Reply With Quote
Old 02-22-2002, 08:23 AM   #4
INITIAL D's Avatar
Send a message via ICQ to INITIAL D Send a message via AIM to INITIAL D Send a message via Yahoo to INITIAL D
Just get something close to it. You don't have to buy the right size because most of the time no one has the right size! I buy something that is about .5mm longer.
INITIAL D is offline   Reply With Quote
Old 02-22-2002, 08:50 AM   #5
jericsm's Avatar
depends on how you got the measurements in the first place. is it from ball to ball?
i would put ball cups in first, then measure from the middle of one shank to the middle of the other shank. i then have a range of lengths i can look for.
you don't need 'exactly' this length. if you do, then you don't need a turnbuckle, cause you are not going to have a chance to adjust it anyway. that's why the ball cups have shanks....
jericsm is offline   Reply With Quote
looking for red tie rods/turnbuckles burbs Electric On-Road 2 02-20-2007 08:49 AM
WTB Collari rods Darrell Skelton R/C Items: Wanted to Buy 1 04-02-2006 09:49 PM
TT-01 Tie Rods browncolin Electric On-Road 2 01-05-2006 07:43 AM
Tie rods karter Electric Off-Road 0 08-27-2004 11:56 PM
AFTER MARKET RODS FOR 12s anybody??? kickass Nitro On-Road 48 05-07-2003 08:27 AM
SEO by vBSEO 3.5.0
