Best 13.5 match for Novak GTB Speed Control ?
Guys,
I race right now 13.5 brushless class on 6 cells NiMH with a Novak GT Speed Control and 13.5 Novak Motor SS PRO.
I will not change my speed for now (i will go for Tekin or LRP for next season starting January 2010), so i need to know for now wich one you think its the best motor to match this speedo ?, its the Novak im using right now the best one ? (must be Roar legal),
thanks,
Pato Concha
Southamerica
thanks,
Pato Concha
Southamerica
Guys,
thanks,
Pato Concha
Southamerica
thanks,
Pato Concha
Southamerica
Guys,
thanks,
Pato Concha
Southamerica
thanks,
Pato Concha
Southamerica
hey guys, how do you advance the timing on novak's ss pro series motors. I understand it can be done but can not find that post again anywhere. I remember it said you need to loosen the 3 hex screws on the timing ring and either rotate the ring all the way to the right or left to advance timing.
has anyone done this and knows how to do it correctly?
thanks.
thanks.
thanks.
thanks.
http://www.rctech.net/forum/3519141-post5020.html
PS: Try the Ballistic 13.5 -- you will LOVE it.
thanks.
thanks.
Company Representative
Ballistic Timing Technical Update (Steve Weiss)
Ballistic Motor Timing Information Update (Preliminary)
In an effort to answer a number of questions relating to motor timing we have compiled some information to help you better understand static motor timing and its effects with our Ballistic Series of motors.
“How many Degrees of Timing does my Ballistic Motor have?”
Our Ballistic motors come with their timing calibrated and set from the factory. Using custom built and calibrated electronic equipment we set each and every motor to 30 degrees of timing. After Calibration the timing label is added and this set timing corresponds to the “N” on the timing label on the side
Each line on the label denotes a 5 degree change, so the timing available on the motor the label corresponds as follows:
-3 -2 -1 N +1 +2 +3
15 20 25 30 35 40 45
N = 30 (rows do not line up correctly)
SPECIAL NOTE: The timing we are describing is the ACTUAL ELECTRICAL TIMING in the motor, not just some arbitrarily reference made from a point on the outside of the motor like many of our competitors' motors. This makes comparing timing settings between different brands of motors difficult without the proper equipment.
“What Does Timing Adjustment do?”
We set our timing at an optimized point for most general applications. Adjusting the timing should only be done in small increments and with great care to observe the changes in system performance and temperatures.
WE RECOMMEND THAT YOUR SYSTEM’S TEMPERATURE NEVER EXCEED 160 DEGREES FARENHEIGHT.
When adjusting the timing, we recommend adjusting the timing, at most, 1 notch, or 5 degrees at a time.
When you turn the timing up to a more positive number (from N to +1) your motor will produce more no-load RPM and generally suffer a slight reduction in torque. To combat excessive heating brought about the loss of torque we recommend gearing down 1 tooth on the pinion for each notch (5 degree increment).
When turning the timing down, to a more negative number (from N to -1) your motor will produce less no-load RPM and generally experience an increase in torque. To combat a loss of top end speed brought about by the loss of RPM we recommend gearing up 1 tooth on the pinion for each notch (5 degree increment).
Ballistic Timing Questions, Part 2
“How do I set my Ballistic to zero degrees of timing?”
The factory timing for the Ballistic is 30 degrees of timing and corresponds to the N on the timing label on the back of the motor.
We do not recommend running zero degrees of timing for most applications and would recommend running at least 5 degrees of timing to ensure proper operation of the motor.
NOTE: When running your timing lower than the pre-set factory 30 degrees your reversing function of your Novak ESC may not work properly as it accounts for this 30 degrees of timing in its commutation sequence.
To adjust the motor to this lower 5 degree timing setting:
1. Loosen the three 1.5 mm hex head screws on the back timing cap of the motor
2. Turn the end-cap clockwise until the stationary notch on the endbell lines up with the edge of the label as demonstrated in the picture below.
[Photos will appear on Novak web-site when we add this update]
3. Re-tighten the three 1.5 mm hex head screws in a circular pattern to ensure that they are all tightened evenly.
-3 -2 -1 N +1 +2 +3
Here is the post from Steve about setting the timing on Novak SS Pro motors:
Hey thanks for the thread & post location.
So how is the ballistic motor better in performance besides the timing adjustments and the fact that is totally rebuildable? Is it also faster
Some customers are reporting a performance improvement. So we will monitor the responses to see what racers have to say. The Ballistic timing is much more adjustable, so that may be offering some advantage.
The Velociti/SS Pro rotors are the same as the Ballistic.
