Has anyone tried drylube for the diff? >
Old 01-25-2004, 10:17 PM
Default Has anyone tried drylube for the diff?
Will dry-lube perform better on the diff and gears than silicone grease?
_______________
Tamiya Evolution III SE
M8
GT7
XTM Mammoth
killerjvf is offline
Old 01-25-2004, 10:32 PM
JusBox's Avatar
Yah because it doesn't attract dust/dirt. Try Paragon lube, you can get it at towerhobbies.com
JusBox is offline
Old 01-26-2004, 10:53 AM
vtl1180ny's Avatar
I use dry graphite lube, you can get it in any hardware store. Sticks to the plastic and is very slippery...
vtl1180ny is offline
Old 01-26-2004, 11:31 AM
mo
mo's Avatar
It sounds like you are wanting to use it on the diff balls too. That would not be a good idea. You need to use a silicone based lube for the balls, otherwise the diff will constantly slip.
mo is offline
Old 02-01-2004, 09:58 PM
Default dry lube
Thanks for the info guys, MO, the dry-lube I found is silicone based. Is this OK for the diff balls too?
Old 02-01-2004, 10:09 PM
JusBox's Avatar
Default Re: dry lube
no use diff grease like stealth lube from associated or another brand.
JusBox is offline
