Can u use 3 2s lipo to make a 6s lipo >
Old 07-31-2013, 09:33 PM
Default Can u use 3 2s lipo to make a 6s lipo
But 1 of the 3 2s lipo is a different
rustler101 is offline
Old 07-31-2013, 09:57 PM
xrayracer1's Avatar
You can, but all 3 packs should be the same.
xrayracer1 is offline
Old 07-31-2013, 11:25 PM
ThePanda's Avatar
Trader Rating: 68 (100%+)
all three packs have to have identical cells, then just connect with a series adapter.
ThePanda is offline
Old 08-01-2013, 05:09 AM
speedy_w_beans's Avatar
You can, but it would be valuable to monitor all six cells and shut down as soon as any one of them drops to a cutoff threshold. Search on HobbyKing for "cell checker" to see some example monitors/alarms.
speedy_w_beans is offline
Old 08-01-2013, 06:23 AM
Tech Legend
Trader Rating: 1210 (100%+)
It is recommended they all be the same, but don't have to be. Even the same labeled 2S could have different characteristics. The biggest part is monitoring cut off if one is a smaller mah. If they are all the same mah but diff C ratings you just have to worry about balancing. If you are just doing speed runs then you should be fine. You will have to balance charge each 2S or build a balance plug if you want to charge/balance as a 6s.
bigwavedave33 is offline
