Old 08-13-2009, 09:20 PM   #1
Johnny Wishbone's Avatar
Default Do you balance your rubber TC tires?
And if you do, what do you use for balance weights? I was thinking of small amounts of epoxy or JB weld, but what do you use?
Old 08-13-2009, 09:25 PM   #2
Small chunks of clay help as well.
MonkeyFist is offline   Reply With Quote
Old 08-13-2009, 09:38 PM   #3
SammyZ's Avatar
Trader Rating: 138 (100%+)
heck no
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 08-13-2009, 09:52 PM   #4
geeunit1014's Avatar
I remember reading somewhere that Paul Lemiux tried this for a while, but the balance changed every run, and it didnt really matter whether he did or not so he stopped. IMO If you can get a sedan tire that out of balance that it truly needs it, you did something impressive. If you fell like it just for the heck of it, use non-hardening modelilng clay, or lead tape.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-13-2009, 10:27 PM   #5
I was wondering this as well. I would think lead tape would be the best thing to use. Ive noticed that my tires seem to be going down in quality. The latest set I bought were poorly glued and they wobble like crazy.
wcalaker is offline   Reply With Quote
Old 08-13-2009, 11:25 PM   #6
niznai's Avatar
Most of the time an out of true tire means not the tire is at fault but the rim. I reuse rims and give them a check before I glue new tires on. Wobbly or unbalanced rims are discarded.
The amount of weight needed to balance a wheel is so minute, I would rather remove some material than add something that can be flung off at any time in a race. Little droplets of CA glue inside the rim are used if you need to load though. Anyhting else is either too heavy or if reduced to the size such that it is the appropiate mass, it doesn't stick well enough anymore.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-14-2009, 03:43 AM   #7
hi, inserts will probably shift around inside the tire and throw it off balance quickly.
rccartips is offline   Reply With Quote
Old 08-14-2009, 10:36 AM   #8
#88driver's Avatar
I didnt know that you were supposed to balance them. I just rotate mine front to rear and thats about it.
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
#88driver is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13244 01-31-2016 07:36 PM
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 08:06 AM
General TC Setup and Handling Tips JoshM20 Electric On-Road 22 05-14-2009 08:43 PM
ROAR Stock TC Guideline Suggestion Greg Sharpe Electric On-Road 179 10-19-2007 01:03 PM
Has touring car for club racing turn-out been low in your area dawgmeat Electric On-Road 159 12-01-2006 08:19 PM
double header: short arms vs. long arms, and fact vs. hype seaball Electric On-Road 100 08-01-2005 11:49 PM
SEO by vBSEO 3.5.0
