3racing F109
#1458
The F104 diff only comes in the F104 Pro, all other cars (F60, MP-24, Wolf, etc) use the old F103 diff which is just a plastic version of the F109 diff.
The first bearing put on the axle fits inside the kit spur gear, Tamiyas metric spurs have much larger hole in them for this bearing, using standard 48 and 64dp spurs you use the thin POM plastic gear adapter instead.
Another question on the F104 pro diff...did anybody else have issues with the end cap with the axle with the wheel bolts on fitting into the actual diff assemble due to the locking nut that tightens the diff does not tighten enough. In other words having the diff at the proper tightness then the diff locking nut is sticking out to far for the end cap with the axle to fit properly. I hope this all makes sense.
Maybe I am just used to the fit and finish of my Xray diffs.
Thanks, Mike
#1461
I don't believe so. I do have the F104 one though. Now that I think about it I did order a bunch of F103 parts years ago that never got put up for sale...let me dig through that box and see if I have one in there.
#1464
#1465
What wheels do I need to run shimizu rubber tires on my f109? The ride wheels only work with ride tires correct?
#1466
51348 Tamiya F103 Spoke Wheel Set
51349 Tamiya F103 Mesh Wheel Set
Please visit www.tqrcracing.com for more information.
#1468
Here is my latest mod, GT wheels. Reason why, is better availability. Our rules say max width 205mm, so I had to cut inner 2,5mm out of each rear tire.
#1470
I made rear adapters, mount them. Cut inner 2,5mm of rear tires on lathe, mount them. Made new longer king pins with self-locking nuts instead of E-clips, replaced front knuckle arms and wheel axles by Associated pan car ones and mount them. Thats it.
