Old 01-02-2011, 12:06 PM   #1411
Default F109 for sale
F109 for sale- Complete car, race ready. It has a new servo (3004), 3200 smc lipo battery, a lrp tc speed control, an epic duo2 motor (21.5), car is new, raced one time. It has one set of foam tires, never been raced (brand new), three sets of front tires and wheels rubber (glued), one set of rear rubber (glued). I still have the box and directions for the car too. I would like to get $300 for it, or best offer.
Thanks,
Floyd Holton
3racing F109-picture-005.jpg   3racing F109-picture-006.jpg   3racing F109-picture-008.jpg
floyd is offline   Reply With Quote
Old 01-02-2011, 02:18 PM   #1412
warnos's Avatar
Like what acid said.. I use 17.5 boosted and use under 1000mah for a 5 min run.. we have 8 min mains and its only ever used 1500 max..
I was running a 5000 but then went to the lightest battery I had a which was a 3700 3 racing battery and it made the car allot faster.. could not justify having the 5000 in there.. the 3700 weighs next to nothing..
Cheers
Originally Posted by GMS_Racing View Post
Awsome thanks just put those 2 parts in my amian basket, is there a rubber tire pref?? I got a set of Ride softs comming, also batterys size, are yall running a full 5000mah or is lighter better?
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 01-02-2011, 04:13 PM   #1413
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Thanks..just making sure i didnt need the weight to make it handle right
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 01-03-2011, 01:04 PM   #1414
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Even if so (my friends running F103GT with TC rubber tires on low grip asphalt did that), its better to put weights on rear pod.
Acid_CZ is offline   Reply With Quote
Old 01-05-2011, 03:45 AM   #1415
GMS_Racing's Avatar
Just wondering if you have to use a low pro servo or if a regualr one will fit, also whats a good starting point for shock spring/oil using rubber tires on carpet...thanks!
Matt Reinders
8ight E 3.0
Elite Performance
Old 01-05-2011, 09:54 AM   #1416
lochness42's Avatar
I'm using KoPropo 2123 with lugs cut off. Definitely low profile servo is nicer fit but not necessary.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 01-09-2011, 10:11 AM   #1417
GMS_Racing's Avatar
What lipo have you guys found that fits good??
Matt Reinders
8ight E 3.0
Elite Performance
Old 01-09-2011, 11:24 AM   #1418
I use DesirePower 5000mAh and have also tested an unbranded chines lipo. Make sure the bullet connectors are out in the corners of the lipo. Otherwise the holes in the top deck have to be modified. I had that problem with the chinese lipo I bought.
Lenght and hight of the Desirepower is good. Width is also ok but I had to use some tape to make it wider.
PatrikAx is offline   Reply With Quote
Old 01-09-2011, 12:00 PM   #1419
wallot's Avatar
any standard hard case pack will fit if it's under 25mm. if it is too low yo can always put some cushioning on top.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 01-10-2011, 02:20 AM   #1420
Looking for some advice on tyres will be running on high grip carpet.What donuts can i buy instead of buying the kit wheel and tyre sets.
neil78 is offline   Reply With Quote
Old 01-10-2011, 03:15 AM   #1421
wallot's Avatar
been using ZEN premounts for last two season and could not be happier.they are quite hard to get these days but you can always get them through
http://www.rc-champ.co.jp/Champ_Inte...onal_index.htm
I use 25shore rear/35shore front combo and it works great. For high grip I would try 30r/35f (or even 38f) combo.
KoPropo Eurus
Old 01-10-2011, 09:33 AM   #1422
Acid_CZ's Avatar
Surprisingly, kit tyres works very well. CA'd outher sides are recommended.
Old 01-10-2011, 01:05 PM   #1423
GasGod's Avatar
Anyone know what caster angle is achieved when you slide the mount all the way to the front?I can't read the #'s on the stock (plastic)parts.Also what is the stock setup(or the preferred) on this part. Any setup help is appreciated,as there seems to be very little avail on the web for this car.
Running silvercan indoor carpet med grip. thnx
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 01-12-2011, 05:03 PM   #1424
GMS_Racing's Avatar
anyone know who has the best price in the carbon chassis??
Matt Reinders
8ight E 3.0
Elite Performance
Old 01-15-2011, 07:03 AM   #1425
Hey guys n gals...
I have just finished commissioning my F109.. The hardware is Novak Havoc 3S and a ballistic 17.5T. 26t pinion, 74t spur. The ball diff is silky smooth. Stuck to IP 3800 lipo, fits nice and lower weight. (and i had 2 left over from TC)
I put in just a little toe in for the moment, and set the front (rake i spose you would call it) to the middle, and the camber to almost zero.
I have noticed that one of the tiny side springs is binding and the plastic doesnt seem to sit inline. Is this a common occurence? Any suggestions.
Cant wait to get it down to the track..
Tyres.. what are the originals like? i have paragon so i would assume use that, same as pans.
Any extra suggestions for a long fast asphalt track?
Just keep tellin her its cheaper than real cars.... safer too
Stangas is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13488 07-24-2017 12:42 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
