Old 12-11-2010, 05:50 AM   #1396
radio_car_racer's Avatar
Originally Posted by efm2 View Post
using a Futaba 2PL AM radio. Will the Futaba suffice or a higher end radio with EXPO the better choice for F1?
EXPO
I only use this to soften the response around zero using no more than 15%
Steering Lock, Individual Left & Right and Overall Travel
If your 2PL has left & right end point adjustment and overall travel adjustment you'll be fine
radio_car_racer is offline   Reply With Quote
Old 12-12-2010, 02:07 AM   #1397
king pin mod found on UK forum
http://rccircuitcars.forumotion.net/...92c1f023e5f3db
Old 12-12-2010, 12:42 PM   #1398
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
It needs login, can you post it here?
Acid_CZ is offline   Reply With Quote
Old 12-12-2010, 03:54 PM   #1399
Originally Posted by radio_car_racer View Post
EXPO
I only use this to soften the responce around zero using no more than 15%
Thanks radio_car_racer.
efm2 is offline   Reply With Quote
Old 12-13-2010, 02:41 AM   #1400
pictures & video by Gazza on rccircuit cars dot com
+ YouTube Video
Old 12-13-2010, 03:27 AM   #1401
Acid_CZ's Avatar
Thanks, thats exactly what I have been thinking of. Did he mention what screws (seems like some ball diff tightening screw) can be used?
Old 12-13-2010, 04:58 AM   #1402
he doen't but it'll need to be one that fits the pivot balls etc
Old 12-13-2010, 10:12 AM   #1403
Acid_CZ's Avatar
Thats for sure. Xrays are 3mm in dia, but i am not sure about lenght.
Another race this saturday, last final.
+ YouTube Video
Old 12-14-2010, 12:01 AM   #1404
tudor_47's Avatar
what motor and ESC is used?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-14-2010, 09:57 AM   #1405
Acid_CZ's Avatar
as mentioned before, 10,5T mostly, 2S lipo, ESC novak, LRP, SP..
Old 12-14-2010, 11:07 PM   #1406
tudor_47's Avatar
Thanks!
Old 01-01-2011, 10:46 AM   #1407
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Ok just picked one of these up with a F103 front end and before i go back and read back 100 pages, are there any upgrdes i gotta do also any setup tips for 21.5 rubber tires indoor carpet?? Thanks!
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 01-02-2011, 03:07 AM   #1408
warnos's Avatar
The CRC is the 1st thing I did....
3racing F109
Helped.. also the aluminium castor block.. but if u have the 103 front end u don't need it..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 01-02-2011, 05:14 AM   #1409
GMS_Racing's Avatar
Awsome thanks just put those 2 parts in my amian basket, is there a rubber tire pref?? I got a set of Ride softs comming, also batterys size, are yall running a full 5000mah or is lighter better?
Matt Reinders
8ight E 3.0
Elite Performance
Old 01-02-2011, 07:48 AM   #1410
Acid_CZ's Avatar
With 21,5T lower weight might be an advantage. Since I am charging cca 2000-2200mAh after 5 min run with 10,5T, 2500-3000mAh should be plenty.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13190 Today 08:44 PM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
