Old 11-27-2010, 12:47 AM   #1366
I figured out a different way to do a CRC spring mod that doesn't use the CRC spring holders or require you to drill out the hole for the set screw. I used a short button head screw and a washer to attach the narrow end of the CRC spring to the top of the stock plastic spring retainer. It fits perfectly that way and doesn't require any modding of the car to do. All that is needed is the springs, a short button head screw, a short counter sunk screw, and a washer. I'll snap a pic later.
Old 11-27-2010, 09:47 AM   #1367
timmig's Avatar
Trader Rating: 25 (100%+)
Oh yeah---I'd like to see it!!!
timmig is offline   Reply With Quote
Old 11-27-2010, 12:25 PM   #1368
Pulled one out of the car today to snap a pic so here it is. You don't get the adjustablilty of the normal CRC mod...but this is easier to do and you don't lose the back 2 screws that hold the upper deck on.
Old 11-28-2010, 02:15 PM   #1369
Have a f109, need to put rubber tires on. I need rims and tires. Who has them in the U.S.? And does the f104 tires fit the f103 rims? race on carpet, so need help. I put f104 on it and the front is too wide, wider thsn the rear. the front is about 8 in wide, and the rear is about 7 in wide. I need a lot of help. Do you have any set up help on carpet for the rubber tires? Thanks, floyd.
floyd is offline   Reply With Quote
Old 11-28-2010, 07:21 PM   #1370
j.d.roost's Avatar
Trader Rating: 28 (100%+)
This has been covered many times..
The 104 rear wheels have a deeper offset.
You need rear 103 tires to make it the same width.
Some have used the 104 offset tires and had good success with it.
We only run foams on carpet where I race so I can't help much there.
If you page back a bit there was a vendor listed selling rubber tires. Or have a look at the 103 103rm threads.
j.d.roost is offline   Reply With Quote
Old 11-29-2010, 09:41 PM   #1371
tommi's Avatar
Hi guys, to those who have already had their F109 front end converted to F104 front...may I know if there's any noticeable difference in handling that's worth doing so? And also if there's any modifications needed or its a direct bolt-on? Thx in advance!
tommi is offline   Reply With Quote
Old 12-02-2010, 02:35 PM   #1372
mini696's Avatar
I remember reading ages ago in this thread that there was a mistake in the manual, where something was shown the wrong way around.
What was it again?
D8, GO 5Port
Ve8, RX8 1900, Promatch 5100 4S
SC10, Hobbywing EzRun
mini696 is offline   Reply With Quote
Old 12-02-2010, 02:47 PM   #1373
warnos's Avatar
caster block.. its in some of the pictures wrong.. if u put it on the way it has it in the manual u will have positive caster..
What was it again?
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 12-02-2010, 04:24 PM   #1374
mini696's Avatar
Which way is the correct way?
D8, GO 5Port
Old 12-02-2010, 05:42 PM   #1375
[QUOTE=mini696;8289715]Which way is the correct way?[/QUOTE
Deleted. :=)
Shawn68z is offline   Reply With Quote
Old 12-02-2010, 08:45 PM   #1376
tommi's Avatar
Anyone?
...and also if THIS servo mount (for F103) can be used in our F109?
http://www.rcmart.com/catalog/rc-f10...h=595_744_1221
Old 12-03-2010, 05:59 AM   #1377
j.d.roost's Avatar
I run the plastic 103 mounts on my 109 so that mount should work.
As far as the front goes I have no clue.
In the words of an old Pontiac commercial "wider is better"
Old 12-03-2010, 06:32 AM   #1378
radio_car_racer's Avatar
fit it so the kingpins are are leaning back at the top, ie like a motorcycle fork
hinge pin holes for upper arms need to be rear most
http://www.rctech.net/forum/attachme...dy-f1s-001.jpg
radio_car_racer is offline   Reply With Quote
Old 12-03-2010, 07:18 AM   #1379
tommi's Avatar
Appreciate the info, thanks!
Old 12-03-2010, 11:50 AM   #1380
Well at our track the F104 tires seem to work the best so yes there was a very noticable difference in handling. But if you can find F103 tires that work then there really isn't a need to do the conversion. The conversion is a direct bolt on. However I did add spacers under the rear bulkheads to lower the rear ride height so I guess I did do some modification. Using the spacers isn't necessary but it seemed to really improve rear grip.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13488 07-24-2017 12:42 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
