Old 09-16-2010, 05:09 AM   #1246
FrankB's Avatar
Default F109 tuning help
I am new to the world of F1 cars and pan style cars in general (had one when I was a kid but was too young to know what to do with it).
What are the basic things to adjust to setup tuning on this car.
Basically, if the car understeers, what should be adjusted.
If the car oversteers, what should be adjusted.
I will be running on a rubberized gymnasium floor with medium front rubber and soft rear rubber tires.
Another question. What pinion gear should I use? I will be running a 10.5 brushless lipo setup and the stock spur if possible.
FrankB is offline   Reply With Quote
Old 09-17-2010, 01:31 PM   #1247
wallot's Avatar
10.5 motor? you must be crazy. for indoors anything faster than 13.5 on life or 17.5 on lipo is too strong.
f1 is all about the tires
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 09-17-2010, 01:36 PM   #1248
FrankB's Avatar
I know 10.5 is a little crazy but I already have it. I am goint to set the timing back and change the throttle curve to the lowest setting.
I will be using the stock foam tires and I also ordered a set of Ride rubber tires to try as well.
Old 09-18-2010, 01:54 AM   #1249
Trader Rating: 19 (100%+)
One thing i will say about F1 racing that you may not be aware of... and somethign that's taking me a while to get the hang of... you have to actually trust your car with f1 racing... dont come to a corner and slow down thinking you wont be able to make the turn... just keep the speed up and youll be surprised how well and responsive the car will move at high speeds.
My main problem is i instinctively brake or slow down and then go to turn and the car has lost all traction by that point and i spin out...
LordAnubis is offline   Reply With Quote
Old 09-18-2010, 09:00 AM   #1250
bjholz's Avatar
Hey guys! Been a while since I posted in this thread. Unfortunatly I traded my F109 for a FT T4. But I was browsin the forum and came across this F1 kit! Check it out!
Yeah Racing TRANSFORMULA is coming in October
Looks downright dirty!
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Savx, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 09-19-2010, 05:22 PM   #1251
lightfoot's Avatar
Default September 25th F1 race
Ultimate F1 Day
Saturday September 25th
Camarillo California , track opens at 7AM for practice
3 min , fast lap Qualifying 10:00 AM
3 15 minute races
2 mandatory pit stops
http://www.charleslightfoot.com/UF1SD.html
Raffle prize #1
Professionally built, F104 Pro, with Tekin RS ESC, Novak 21.5 motor,
2.4 receiver, Orion 3200 lipo, Shimizu rubber, Calvinization modification, custom painted F60 body from F1 Paint-lab...
Ultimate RTR F1... just bind to your radio and
go... estimated cost $920
Raffle prize #2
Tamiya F104 Ferrari Kit
Each racer will have their name placed in a container... after each race, if you did NOT receive a penalty your name
will be placed again in the container, increasing your odds of winning... Also after each race, the announcer and the
pit marshal will each choose one person who they felt was the cleanest driver of that race, regardless of how they
finished and there name will be added again to the container... Basically the cleaner you drive all day, the better
your chances of winning the prize Also, in case of a tie, the driver with the least amount of penalties win...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 09-22-2010, 03:09 PM   #1252
Default F 1 Race in Carbondale!!!
Hi Guys,
We're hosting the Alpha Cup F-1 Challenge in Southern Illinois October 9th, 10th. We'll be giving away two "Skip Barber Intro to Racing Gift Certificates" by random draw of entries. Details are located here:
http://mysite.ncnetwork.net/resqsghf/alphacup2010.htm
You can also inquire or post questions on the Southern Illinois Carpet Racing thread.
Skip Starkey
alphacat is offline   Reply With Quote
Old 09-23-2010, 12:00 AM   #1253
CypressMidWest's Avatar
So you're saying no "Hamiltonesque" passing attempts?
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 09-23-2010, 10:10 AM   #1254
lochness42's Avatar
Ah, finally I have my own F109.
Which wings do you recommend and what is your opinion on diffusers?
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 09-23-2010, 01:58 PM   #1255
InZane's Avatar
Default Greetings from Sweden
5 victories out of 6 possible in the Swedish F1-Cup! 3Racing F1-09 ROCKS!!!
InZane is offline   Reply With Quote
Old 09-23-2010, 06:02 PM   #1256
FrankB's Avatar
Hey guys, I still need some help. My F109 has finally arrived and I am in the process of putting it together.
I still have to get some pinions but I don't know where to start. I'll be running the stock spur gear with a Novak 10.5 brushless system. The car will be run on a large indoor track with a 100 foot long straight away and mix of sweeping and hairpin corners. I want to find the best setup for keeping the ESC and motor cool.
Suggestions?
Old 09-23-2010, 09:52 PM   #1257
Suggestions?
Single cell or 2s? If you're running 2S get a larger spur, maybe a 110, so you won't have to use tiny pinions. We're running 2S, silver can brushed motors and a micro 20 pinion with a giant 118 spur, on the stock foams, which actually work quite well. Our track is significantly shorter, but a silver can is probably less than half the motor when compared to a 10.5.
Old 09-23-2010, 10:48 PM   #1258
robk's Avatar
Trader Rating: 22 (100%+)
Congrats!!!!!
Old 09-23-2010, 10:50 PM   #1259
robk's Avatar
Suggestions?
Motor down
It's gonna be super fast. I ran a HPI Super F1 that used 1/10 pan foams on a 10.5 2s and it was actually scary.
You might want to try a 17.5 just to see how fast it will be.
Old 09-24-2010, 03:46 AM   #1260
FrankB's Avatar
I will be running 2S. I was considering running a 17.5 but spurs and pinions are alot cheaper.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13158 Today 09:53 AM
Tamiya F104 Pro! NT Electric On-Road 9356 Yesterday 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
